Help me identify this noise!
Discussion in 'Technical Chat' started by GA_TACO4x4, Jun 18, 2011.
  1. Jun 18, 2011 at 2:37 PM
    GA_TACO4x4
    GA_TACO4x4 [OP] Well-Known Member
    here 'n there
    07 DCSB 4x4
    marathon superhide max-4 seat covers, weathertechs, maglite mod, 20% tint, 2" leveling kit, leaf spring tsb.
    Ok lately my trucks been making a strange grinding noise. It started a few weeks ago and would come and go. But now its gotten worse and louder. Its definitely coming from the engine and seems to occur when the engine is under a load around 1000 rpms. I've also noticed it'll do it while idling in traffic (again around 1000 rpm). Here's a video i just took with my old and outdated camera...hopefully someone can help me pinpoint this!
    http://s90.photobucket.com/albums/k261/jjones_1028/Tacoma/?action=view&current=P5260001.mp4
  2. Jun 18, 2011 at 2:39 PM
    YeahYeah
    YeahYeah Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
    i wanna say idler pulley.
  3. Jun 18, 2011 at 2:43 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I have a similar issue. I don't know if its the same noise, but my air filter bounces sometimes and can knock either the cai box or the hood. Check that first! GL
  4. Jun 18, 2011 at 2:46 PM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    how hard/expensive is that to replace?
    im 99% sure its not the cai. it was making the noise before i installed the kit. thanks for the suggestion though!
  5. Jun 18, 2011 at 3:07 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    My truck makes a similar noise. I haven't had to time to address it, but I think it's the fan hitting the shroud when the engine torques under load. Mine does it mostly when in reverse but always around 900 to 1000 rpms. My first guess would be a bad motor mount. But then again I haven't done any diagnosis to verify. If you do fix it, I would like to know how.
  6. Jul 11, 2011 at 10:21 PM
    Marioso
    Marioso El Pitufo
    San diego Ca
    05 debadged trd sport
    2.5 FRONT LIFT, DEBADGED, TRD OFF ROAD WHEELS, RUGGED TRAILS
    you guys seem so laid back about it. go underneith. its the fucking motormount haha!. i had to fix mine last year. everything u are saying describes my problem. go to a fab shop and have em pull the mount out of the broken frame and reenforce it. if they tell u that the engine needs to be pulled out theyre bullshitting u. dont bother going to a dealership, theyll blame it on u if theres any sign of offroading!!!!!!!!!!!!!
  7. Jul 12, 2011 at 7:17 AM
    NelsonTacoma
    Tucson, AZ
    I've checked that on my truck. The motor mounts are not sunk into the frame. I initally thought that would be the answer, but it's not. But it's def a good thing to check.
