Help me in rust prevention.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaTD13, Jun 14, 2013.
  1. Jun 14, 2013 at 9:54 AM
    TacomaTD13
    TacomaTD13 [OP] Well-Known Member
    Kevin
    King of Prussia, pa
    TRD Sport
    Has anyone do anything to prevent rust from undercar? I plan to keep my Tacoma for a long time and rust seem to be an issue especially here in the eastcoast that deal with road salt in the winter. Any advice will greatly appreciate.
  2. Jun 14, 2013 at 9:56 AM
    709GADE
    709GADE Well-Known Member
    '09 Toyota Tacoma 4X4 SR5 DC LB - Pyrite Mica
    Toyota aluminium side steps, Toyota door sill protectors Extang trifecta tonneau cover, U-Haul Class 3 hitch, Black Weathertech's, Front mudflaps trimmed 4", OEM Fog Lights, WeatherTech Bug Deflector, 13" Stubby antenna, TRD Skid Plate, ScanGaugeII, Carriage Works Billet Grille, Plasti Dipped overhead temp/compass console, LT265/75/16 Duratrac's LR C
    Wack tonnes of oil underneath the truck and anywhere metal will be exposed to salt.
  3. Jun 14, 2013 at 10:04 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    It all comes down to one thing. Do not allow the environment to come into contact with metal. There are many ways to do this. As mentioned above, oil is a shield, albeit a temporary and messy one. Coatings such as Rust Bullet, Zeibart, et al are another way. I tend to prefer the coatings. If they are strong to prevent chippng and thick enough to ensure a proper shield from oxygen and moisture, they will 100% prevent rust.
  4. Jun 14, 2013 at 10:04 AM
    WTFaulkner
    WTFaulkner Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
    I used a wire brush and then washed it then used this rustoliem product that bonds to the rust dry's it out and kills the rust turning it to a paintable surface then the next day hit it up with a rustoleum clear coat and let it dry and done!!
  5. Jun 14, 2013 at 10:16 AM
    TacomaTD13
    Kevin
    King of Prussia, pa
    TRD Sport
    If spray with clear coat, how often do you have to respray it. Is there any part if the undercar that should not be spray.
  6. Jun 14, 2013 at 10:21 AM
    TacomaTD13
    Kevin
    King of Prussia, pa
    TRD Sport
    Seem like a messy job, plus I don't like dirt or debri stick on the oil.
