Help me make my suspension right.
Discussion in 'Suspension' started by SeNate, Apr 5, 2013.
  1. Apr 5, 2013 at 3:28 PM
    SeNate
    SeNate [OP] Well-Known Member
    Salt Lake City
    05 SR5 TRD 4x4 6spd
    Satoshi Grill (HomerTaco), Ambiguous' headlights, refinished my frame with POR-15 after half a week of prep and rust removal
    I'm still reading the stickies, but it is all a little overwhelming. My previous thread, I posted some pictures of my lift, trying to figure out what it was. I have a 3" spacer lift, and the back is add a leaf. Not only did you guys tell me to go for Billstein 5100's, but a friend of mine took a look at it and said the same exact thing.
    I really want to keep the 3" lift, and if I am reading this correctly, the Billstein 5100's adjust up to 2.5". My question now is with Billstein 5100's all around, is there anything else I should look at? From what I've been reading OME's 885x would be a good way to go (which would also help me to hit 3" mark?). I also have the money to just invest in a pair of leaf springs for the rear.
    What about control arms?
    I'm new to this, I just don't want to do something wrong. I am also going to have to research how to get this massive surface rust off. Salt lake city is horrible in the winter. I do take it off road sometimes, so this isn't only a ride comfort thing.
    I really appreciate all the help. I will continue reading all of these stickies, I just don't know where to start.
    Edit: Would a coilover kit be the best option?
  2. Apr 5, 2013 at 4:04 PM
    TherealScuba
    TherealScuba Well-Known Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    The front 5100's are a great option for a low cost lift.
    They'll offer a nice ride, but will still have characteristics of a preloaded coil spring, just FYI.
    https://www.allprooffroad.com/05tacomafrontsuspension/144
    For the rear, check out our 3" lift spring and full kits, they come with everything you'll need to complete the lift and get rid of those ugly AAL's
    https://www.allprooffroad.com/05tacomarearsuspension/05rearsuspension
    Let me know if I can answer any more questions for you.
    -Stephen
  3. Apr 5, 2013 at 4:06 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    Mini H1 Retrofit 5K, 1st Gen TRD CAI, JBA Catback, Radflo 2.5 extended coilovers w/ resis, Radflo 2.5 rear shocks with resis, toytec superflex rear springs, DSM Uniball UCA's, intake manifold spacer
    OME 885 coils, bilstein 5100's set to 0, light racing upper control arms, and keep the aal, just my opinion, you'll be dead level.
