Help me not make a mistake!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AMS13, Feb 26, 2015.
  1. Feb 27, 2015 at 10:28 AM
    Yota64
    Yota64 Professional Threadjacker
    Props to op for not coming on and getting butthurt / leaving. Most new people with these kinds of responses do. Hope you find the Tacoma for you OP. like I said eibachs and billies at 0.85 are the cheap 2.5 lift option and provide a stiff ride. I'm not sure which is stiffer, billies at 2.5 or what I just said.
  2. Feb 27, 2015 at 3:01 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    2.5" spacer front and rear airbags set at 60lbs for the ultimate stiff and shitty ride
  3. Feb 27, 2015 at 6:05 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    "You are what you eat"... so they say. :D
  4. Feb 27, 2015 at 10:22 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I have heard that was so.... Hmmmm
  5. Feb 27, 2015 at 10:41 PM
    bzzr2
    bzzr2 Well-Known Member
    hey OP, just keep looking for a stock truck that meets your criteria, the suspension will be soft on used tacoma in you price range, you will need to plan on spending a few bucks to fix that after purchase. if you want a firm ride either pick up some bilstein or ome fronts, along with an add a leaf for the rear and a stiffer rear shock. the steering is what it is, i never once thought it was bad, my brand new 2015 jeep jk doesn't steer on the road anywhere near as nice as my tacoma did.. just be aware that your mpg will still not be very good with the 4cyl engine, but will be a little better than the v6 until you load it up, then it feels a bit weak but if speed is not of concern then it does the job. good luck!
