Help me out with guessing the Tire Size on this truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MonkeyWrench462, Nov 7, 2016.
  1. Nov 7, 2016 at 8:50 PM
    MonkeyWrench462
    MonkeyWrench462 [OP] Well-Known Member
    Christopher
    Minnesota
    2013 Tacoma TRD
    K&N Air Filter, Supreme Suspension 3" Lift, Daughters First Pair of vans from Mirror
    I have always liked the way this truck looks. This is the same color and body style as mine. Can anybody take a guess at what size tires is on it????
  2. Nov 7, 2016 at 8:52 PM
    5lugturtle
    5lugturtle Well-Known Member
    Conner
    San Diego
    2012 Silver Tacoma 5 lug regular cab 2x4
    Lift,31s
    285s or 33s. rim looks like a 16 or 17.
  3. Nov 7, 2016 at 8:59 PM
    Pigpen
    Dan
    Northwest Montana
    If those are 33s, they're on 17s. The sidewall looks short IMO.
  4. Nov 7, 2016 at 9:01 PM
    5lugturtle
    Conner
    San Diego
    Lift,31s
    yeah they look like 17s and 33s
  5. Nov 7, 2016 at 9:02 PM
    MonkeyWrench462
    Christopher
    Minnesota
    2013 Tacoma TRD
    Right now I have a 3" lift and I got some Pro Comp Alloys Series 69 Wheel (17x9"/6x139.7mm) that are waiting for tires. Would I be able to go up in size tires (from the 265/65-17 without any modifying?
    5lugturtle likes this.
  6. Nov 7, 2016 at 9:03 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    But thats indigo ink pearl and if you have a 13 you'd have blue ribbon metallic :boink:
    Anyway, this is what an Indigo ink looks like on 32s
    17x8 (0mm offset) FN Konig Six Shooter with LT265/70R17E Cooper St Maxx
    tomwil likes this.
  7. Nov 7, 2016 at 9:04 PM
    AR15xAR10
    Because you have such a wide wheel, you could go to a 265/70r17 and have a bunch of tire poke outside the fenders. But that also depends on the shoulder of the tire you go with.
    Any current pictures of your truck?
  8. Nov 7, 2016 at 9:05 PM
    Pigpen
    Dan
    Northwest Montana
    255/85/16 (true 33) on 3" lift
    AR15xAR10 likes this.
  9. Nov 7, 2016 at 9:06 PM
    AR15xAR10
    I think your best bet would be a 255/80r17 if you want a bigger tire. But you will have to do a little tiny bit of trimming up front.
    Tractorman likes this.
  10. Nov 7, 2016 at 9:15 PM
    MonkeyWrench462
    Christopher
    Minnesota
    2013 Tacoma TRD
    This is mine
  11. Nov 7, 2016 at 9:17 PM
    AR15xAR10
    So you haven't mounted the procomp wheels yet...
    How big of a tire do you want?
  12. Nov 7, 2016 at 9:17 PM
    MonkeyWrench462
    Christopher
    Minnesota
    2013 Tacoma TRD
    BLUE of some sort:):):)
  13. Nov 7, 2016 at 9:20 PM
    5lugturtle
    Conner
    San Diego
    Lift,31s
    Get some 35s! :bananadead:
    eccracer104 likes this.
  14. Nov 7, 2016 at 9:20 PM
    Pigpen
    Dan
    Northwest Montana
    Depending on how much those wheels stick out, it could be more than a tiny bit of trimming.
  15. Nov 7, 2016 at 9:21 PM
    MonkeyWrench462
    Christopher
    Minnesota
    2013 Tacoma TRD
    No i havnt and to be super honest not sure about tire size. I am thinking just a little bigger then stock.
  16. Nov 7, 2016 at 9:22 PM
    Pigpen
    Dan
    Northwest Montana
    3" lift on stock UCAs... you're going to have fun keeping her on the road with a wheel that pokes out of the wheel well.
  17. Nov 7, 2016 at 9:26 PM
    MonkeyWrench462
    Christopher
    Minnesota
    2013 Tacoma TRD
    Plus I cant beat the price of the stock size
  18. Nov 7, 2016 at 9:26 PM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    X2 for indigo ink :bananadance::taco:
    AR15xAR10[QUOTED] likes this.
  19. Nov 7, 2016 at 9:27 PM
    5lugturtle
    Conner
    San Diego
    Lift,31s
    go with 32z
  20. Nov 7, 2016 at 9:34 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Don't forget that you have a 9" wide wheel. Check the tire size to make sure it'll mount a wheel that wide.
    My vote goes to 285/70-17 but you'll probably rub unless you trim your fender liner.
