help me out
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco man95, Mar 30, 2014.
  1. Mar 30, 2014 at 10:45 AM
    taco man95
    taco man95 [OP] New Member
    Virginia
    99 v6 tacoma
    I have a 99 v6 tacoma its lifted 3" on suspension but I wanna run 33x12.50s without having to cut a lot or none at all how much body lift should I run??
  2. Mar 30, 2014 at 12:07 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    First off, welcome to Tacoma World!
    So, I have a couple questions for you.
    1. Do want to just run your truck on the street, or will you take it off road?
    2. What is the backspacing on your rims?
    Basically, I think you have to cut/grind to get 33x12.5s to fit for wheeling but the offset on your wheel will affect how much is required.
  3. Mar 30, 2014 at 1:05 PM
    taco man95
    Virginia
    99 v6 tacoma
    Im going to be offroading a little not going to do to much flexing and twisting up and I have 3.75 backspacing
  4. Mar 30, 2014 at 1:06 PM
    taco man95
    Virginia
    99 v6 tacoma
    I was thinking either 1-2" of body lift
  5. Mar 30, 2014 at 4:22 PM
    Lumpskie
    New Hampshire
    ^I, personally, would not go any more than a 1" body lift. Anything more and they get sketchy, if you ask me.
    With 3.75 backspace rims and a 1" bodylift you might be able to just trim your pinch weld and be done with it.
  6. Mar 30, 2014 at 5:43 PM
    taco man95
    Virginia
    99 v6 tacoma
    Even with a little offroading you think 1" would be enough?
