Help me pick a lift....
Discussion in '1st Gen. Tacomas (1995-2004)' started by gbollom, Nov 3, 2016.
  1. Nov 3, 2016 at 9:05 AM
    gbollom
    gbollom [OP] Well-Known Member
    Weatherford Tx
    01 xcab TRD 4x4 5spd
    ....and maybe tire size and back spacing
    Ok ok i know these threads pop up all the time, but Im frankly tired of reading old threads.
    This truck will see its fair share of highway use, but will also be used off-road on the ranch and for hunting. Will not see any hard core trail specific use, but will see its fair share in its previously mentioned intended use.
    I know i want aftermarket UCA's and full leafs in the back.
    Ive looked at both the all pro kit with these features as well as the toytec ultimate with UCA's and full leafs. Either one of these lifts significantly better than the other? Or is there another option at a similar price point?
    Also can I get 33's under the truck with the proper back spaced wheels?
  2. Nov 3, 2016 at 12:06 PM
    jaytrd02
    jaytrd02 Well-Known Member
    2004 Mystic Gold Tacoma TRD 4x4
    I recently put a 3" OME kit on mine. Only did the coils, no UCA's and went with an aal in the rear. I am happy with this kit as I have similar use as you mention. With this kit you could add UCAs and the dakars in the rear if you wanted. installed I paid about 1400, but I priced the kit thru toytec and would have run me about 9 and change. The guy also put me a new needle bearing, I guess a common problem that comes up once lifting these.
  3. Nov 3, 2016 at 1:44 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    budget? your already over a grand with ucas and leafs.
  4. Nov 3, 2016 at 1:45 PM
    gbollom
    Weatherford Tx
    Both of the lifts I posted above with UCA's and leafs are about $2200 right off of the top of my head. Or within $200 of that
  5. Nov 3, 2016 at 1:51 PM
    eon_blue
    Azusa, CA
    Based on your usage, Id go with either an OME kit or 5100s/OME coils. I have 5100s at .85 with 881s and 3 leaf AAL in the rear, suits me fine for under a grand total. Recently added LR UCAs for another $400
    jaytrd02 likes this.
  6. Nov 3, 2016 at 1:58 PM
    gbollom
    Weatherford Tx
    Reason for suggesting this over the kits I inquired about? Not questioning your suggestion just learning
  7. Nov 3, 2016 at 2:21 PM
    eon_blue
    Azusa, CA
    Nothing wrong with the ones you listed, I was just throwing out a couple other options I'm personally familiar with (and are a bit cheaper I think).
  8. Nov 3, 2016 at 2:27 PM
    medic2230
    Murph
    Bama! Roll Tide
    Full 3" OME lift with Dakars. Add some Light Racing UCA's and you're in business.
  9. Nov 3, 2016 at 2:58 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Right now I've got the 5100's on all 4 corners, with the fronts on the middle ring (~2" lift) and a 2" extended shackles out back and 265/75R16's. I will likely go up to the full 3" here in the next week or so because my coils have sagged a bit.
    This is all just a band-aid until I can go for a "legit" lift.
    I've been doing a lot of reading lately on this subject and here's what I *plan* to do, based on my research, and reading other people's testimonials.
    I'm planning on the All Pro "pro" kit with the full leafs to replace my aging stock ones ($1400). Then I'll likely go for the Camburg UCA's ($665). This will be step 1 of my Overlander build, since hopefully soon my '04 won't be my daily driver.
  10. Nov 4, 2016 at 12:13 AM
    brother moses
    brother moses Well-Known Member
    Brandon
    Washington
    02 Double Cab Supercharged
    Light Bars, deck plate mod, Camburg 2.5 coil overs, Dakars, AP sliders, NWTI Bumpers
    id recommend whichever brand you choose, be it allpro, dakar, deaver, wheelers, etc. choose a full leaf pack. the stock leafs are wear items and in my $.02 opinion, severely limited from the get go. adding a leaf would be a bandaid fix, similar to me adding lift shackles and spacers to compensate for my offroad bumpers before finding coil-overs and dakars.
  11. Nov 4, 2016 at 4:45 AM
    gbollom
    Weatherford Tx
    Full leaf pack is definitely on the list regardless of source
    brother moses[QUOTED] likes this.
  12. Nov 4, 2016 at 3:42 PM
    Rmartin517
    Rmartin517 Well-Known Member
    Robert
    Texas
    2001 4 door Tacoma limited trd
    Supercharger, 6" fab tech, 20" moto metal wheels, 34" Nitto trail grapplers
    If your gonna spend over 2k may as well go with the fabtech. My only complaint about the lift is how stiff you have to compress the front coils for the fab tech strut. I've done some off-road and some rides to the beach. Most of the time I spend on the road.
