Help me pick a lift
Discussion in 'Suspension' started by Databox, Jun 25, 2022.
  1. Jun 25, 2022 at 10:59 AM
    Databox
    Databox [OP] Well-Known Member
    Fernandina Beach, FL
    2007 TRD Sport SR5
    Rims and Tires
    I drive a 2007 TRD Sport double cab. It has a Readylift leveling kit currently installed on it.
    No armor or plans for any.
    I went up in tire size to 33's. Now I want a lift in the range of 2.5" to 3".
    Like most I'm on a budget. I've found 3 different lifts that with some July 4th sale pricing are in my price range. I'm having trouble deciding which one gets me the most bang for my buck.
    Let me know your thoughts or if you'd recommend something completely different.
    Lift number 1: $1900 (roughly...with sale price)
    NITRO GAS SUSPENSION KIT SUITED FOR TOYOTA TACOMA 2005+ - STAGE 2
    Lift number 2: $1600 (roughly with SPC UCA's and Dever AAL)
    HEADSTRONG OFF-ROAD
    • OME Coil/Bilstein 5100 Kit - (HS05BK-1)
    OME COIL/BILSTEIN 5100 KIT - (HS05BK-1)
    $710.28 - $1,676.22
    This kit is the perfect solution for those who don't want to spend a lot of money yet want a kit that can handle the trails. The kit comes complete with everything needed to both lift the truck and improve the suspension for the typical weekend warrior. The Bilstiens work wonders controlling the changing terrain while sustaining the quality of on road ride, the OME coils better support the trucks front end weight over the factory coils while still offering plenty of flex. Also included in the kit is a 1/4" top plate spacer that can be used to help eliminate the drivers side lean.
    Rear options are available in order to lift the rear. Options include our HS 3-leaf add-a-leaf or the Deaver single leaf AAL. Either of these AALs will lift the rear approx. 1.5"-2" without drastically altering the quality of ride. Our 3 Leaf AAL includes new ubolts whereas the Deaver AAL will work with the existing factory ubolts.
    Lift number 3: $1750 (with SPC UCA's)
    Rogue Offroad
    Bilstein 5100 with OME springs & Mini Pack
  2. Jun 25, 2022 at 11:03 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I like #2 & #3.
    ZColorado likes this.
  3. Jun 25, 2022 at 11:17 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    #2 looks pretty good. Just curious... what tire size is your 33" and what did you have to trim to get them to fit... assuming the leveling kit was 2" up front?
  4. Jun 25, 2022 at 11:29 AM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    It is a 2" leveling kit.
    Yes I trimmed, but mainly the plastic shroud up front. I still get rubbing when I turn hard.
    My tire size is 275/70/R18. The Nitto Terra Grapplers. Love the tires...my second set
  5. Jun 25, 2022 at 12:10 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    100% you should factor in a cab mount chop/relocate in the project.
    Databox[OP] likes this.
  6. Jun 25, 2022 at 12:29 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Might want to ask @memario1214 if there are any upcoming sales to look forward too… or if maybe you can get the 6112 for up front and the 5110 in the back. Just a thought…
    I have the Ironman Foam cells and really like them but can comment on the nitros… @ohcaltexscar can probably answer your questions about it though.
    Databox[OP] and ohcaltexscar like this.
  7. Jun 25, 2022 at 2:36 PM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    Southwest Ohio
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    I really like the Ironman nitros, I’ve had a great experience with that kit. People can poopoo all they want about the brand or whatever, it has been a fantastic kit.
    I would just suggest you get the lightest spring options, performance load stuff. Unless you know for sure that you want heavier spring rates.
    The spring rates are adjusted for the Tacoma (I spoke with them about this) but are still based on their Hilux kits.
    Databox[OP] and hyrule_trd like this.
  8. Jun 25, 2022 at 4:20 PM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    Good info. Thanks
    ohcaltexscar[QUOTED] likes this.
  9. Jun 26, 2022 at 3:09 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I lile the iron man lift the best.
    I don't like ome coils they sag to much.
  10. Jun 26, 2022 at 7:05 PM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    I will be doing the CMC.
  11. Jun 27, 2022 at 9:46 AM
    Lucy4227
    Lucy4227 New Member
    I have the Ironman 4x4 state 2 but with Foam Cell Pros and I am extremely happy with it. When I was looking at lifts one of the deciding factors for me was the leaf springs. My leaf springs were pretty flat, so instead of putting what I considered a band-aid and putting on a add-a-leaf. I replaced the whole thing with the new leaf springs. The FCPs are a great ride and I have had nothing but an excellent experience with Ironman thus far. If bilsteins ride ANYTHING like the stock ones that came with the TRD OR, then Ironman wins hands down as from my experience my truck feels much more planted and less bouncy.
    ohcaltexscar and hyrule_trd like this.
  12. Jun 27, 2022 at 2:57 PM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    LIFT NUMBER 2 FOR THE WIN!!!!
    Just placed my order!!!!
    ohcaltexscar likes this.
  13. Jun 27, 2022 at 4:06 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Totally missed this tag until now, but it looks like @Databox dropped an order in already! You made a good choice. Hopefully they have those front 5100s in stock! We've been struggling to get a hold of them... If they don't and decide to pivot to something like a 6112 let us know as we have SPC arms, 6112s, etc all in stock here. Enjoy!
  14. Jun 27, 2022 at 7:07 PM
    ohcaltexscar
    Chas
    Southwest Ohio
    Good luck with that one, a lot of guys like it!
    hyrule_trd likes this.
