Help me pick a truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by MEDICMAN, Nov 14, 2015.
  1. Nov 14, 2015 at 10:27 AM
    MEDICMAN
    MEDICMAN [OP] Member
    2001 Tacoma V6 TRD Toytec lift.
    Bully bar, Unknown lift, Rhino Bedliner
    2004 extended cab trd manual v6 90k
    Or
    2006 Tacoma extended cab trd v6 150k both are going for about $14,000
    Help me pick
  2. Nov 14, 2015 at 10:41 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Really? Are you trying to start a fight? Or just trolling? o_O
    JLee and VandalTaco like this.
  3. Nov 14, 2015 at 10:41 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I vote for the 2004.
  4. Nov 14, 2015 at 10:43 AM
    reef
    reef Well-Known Member
    04 4WD
    yeah this could go very bad.
  5. Nov 14, 2015 at 10:55 AM
    MEDICMAN
    Nope. Just in a buying dilemma. Hoping you guys can help me pull the trigger on one.
  6. Nov 14, 2015 at 10:57 AM
    Nowhereman04
    Nowhereman04 Well-Known Member
    Tar Hill Blue NC
    Silver 04 DC 4x4 SR5 TRD OFF ROAD
    Bilstein 5100's front, Bilstein 5125's rear
  7. Nov 14, 2015 at 10:58 AM
    Taco gator
    Taco gator Taco with 6.5" front 0" rear lift
    J.D.
    Lakeland, FL
    2014 2wd Taco
    6.5" Spindle/5100 lift front lift
  8. Nov 14, 2015 at 10:59 AM
    reef
    04 4WD
    I'm gonna say the 04 also because the low miles
  9. Nov 14, 2015 at 11:00 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    '04 would be worth it simply due to the miles. If you're wanting more space, the '06 would serve you well. Any blemishes on the '04 that would deter you? I'm sure they both have scratches and such, but what about seat wear?
  10. Nov 14, 2015 at 11:06 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Doesn't say where you live. Big city I would go auto. Country stick.
    04 is first gen, 06 2nd gen. Different HP. I believe the 1st gen has a timing belt, 2nd gen timing chain.
    I don't know
  11. Nov 14, 2015 at 11:08 AM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    I wouldnt buy a vehicle with 150k miles for 14 grand unless I knew the owner and knew it was cared for. Even if it is a Tacoma. For a few thousand more you could find a second gen with less than 100k. My vote is for low miles.
  12. Nov 14, 2015 at 11:10 AM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Well....if your going to wheel it, 04 cause its smaller.
  13. Nov 14, 2015 at 12:08 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    1st gen , because I'm a 1st gen fanboy..... but like someone said, if you need the space, maybe the 2006 will fit your needs better.
  14. Nov 14, 2015 at 12:31 PM
    tacomagirl85
    tacomagirl85 New Member
    Tonia
    Port Richey, Fl
    04 4wd TRD SR5 Manual
    33" all terrains, 3 in supension lift
    I own a 2004 and wouldn't trade it for the world.....with that said I am in the process of doing a motor swap on it cause the tps sensor went out on it and it's 1500 to replace it. Its ultimately your choice just wanted to give you something to ponder.
  15. Nov 14, 2015 at 12:39 PM
    reef
    04 4WD
    1st Gen for the win in here!
  16. Nov 14, 2015 at 2:36 PM
    josh843
    josh843 Well-Known Member
    Josh
    moncks corner, sc
    2001 reg cab prerunner
    1st gen FTW
    plus the milage issue
  17. Nov 14, 2015 at 2:48 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I had the same thing when I bought mine and I went with the 02 over the 06.
  18. Nov 14, 2015 at 3:53 PM
    DJB1
    Dave
    SLC, UT
    I bought a 2nd gen 1st and a 1st gen 2nd. I like the 1st gen better.
  19. Nov 15, 2015 at 5:16 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    My vote is for the 04.
