Help Me Pick An AMP!!!!!
Discussion in 'Audio & Video' started by wolfgang123, Nov 30, 2009.
  1. Nov 30, 2009 at 7:01 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    http://www.crutchfield.com/p_113KDCX492/Kenwood-Excelon-KDC-X492.html?o=r&tp=5684
    so thats the Radio i got in my truck now, no tweeters installed and when i bought the truck it already had some sony speakers installed (4 total apear to be all the same) i will get more info on those tommarrow. so i need an amp and a sub (8 or 10 inches max) but this thread will mostly be about the amp.
    How much should i spend?
    how do i wire it up??
    What?????
    Help please, and thank you
    Wolfie
  2. Dec 1, 2009 at 5:04 AM
    ENIGMA206
    ENIGMA206 Well-Known Member
    Palm Bay, FL
    07 4X4 Off-Road DC
    Tunes Tonneau On-board Air Firestone Air Bags
    Wolfie,
    It really all depends on your goal of a system. If you're just wanting to improve overall sound and a good clean look, you don't need to invest much. If you're wanting to end up with a couple of 10" and wake up the neighbors, the application will be totally different. You're going to get a lot of different opinions.
    Myself, I like a clean, minimalist type system. I like running 5-channel amps. They are really easy to set up and have a clean look to them. Most five channel amps provide 45 to 70 watts per channel on your door speakers. The mono sub channel will provide about 200 to 300 watts. They will work with a multi-sub set up, but you will be asking a lot from that amp. A single sub works well with the 5-channel amps.
    As for cost, it is endless. If you go 5-channel, it can start at $100 for a Crunch amp or go to $1000 for a JL amp. It's all up to you on what you want to put into it. I am a firm believer that you get what you pay for, so I try to hit middle ground.
    I just installed a low-end Hifonics amp, a 10" Pioneer shallow mount sub, Polk MOMO 6X9 in the front and Polk MOMO 6.5" in the rear of my double cab. I will be upgrading the amp in the next few weeks. My biggest mistake was not going component speakers in the doors.
  3. Dec 1, 2009 at 5:09 AM
    cole47
    cole47 Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
  4. Dec 1, 2009 at 6:32 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i am looking for good bass (i dont need to be waking up the neighboorhood with it though) and clear vocals and sound. i have no idea what you mean by -channels- and -watts- is there a limit to what i should have. i dont know what range i should be looking for.
    i dont want to spend more then 250 on the amp.
    thanks again
    wolfie
  5. Dec 1, 2009 at 6:56 AM
    ENIGMA206
    Palm Bay, FL
    07 4X4 Off-Road DC
    The number of channels refers to how many speakers you want to feed. A 4-channel amp runs four speakers. A 2-channel amp runs two speakers. We won't even get into the parallel/series thing right now. The 5-channel amp will run 4 speakers in stereo and 1 mono sub.
    Are you wanting to put speakers in each door or just in the front?
    As for watts, that is the power rating of the amp to each speaker. The amp output needs to closely match the speaker's capacity. Too much amp power will smoke the speakers. Too much speaker consumption will smoke the amp.
    I really recommend that you go on CRUTCHFIELD.COM and go to the educational section. It is a great source to learn this stuff.
    You can get a good amp for $250, but certainly not Alpine or JL unless you find some used. But if you decide to go with seperate amps for doors and subs, you will be hard-pressed to find two amps for that kind of dough.
  6. Dec 1, 2009 at 7:06 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I'm running an alpine MRP-F300 in my double cab. The front channel powers my front speakers which are Alpine type-s 6.5 inch components and the back channel is bridged to power a 10" infinity reference DVC wired @ 4ohms in a custom sealed box behind the rear passg side backseat. I'm not running any rear speakers. Its not a super powerful but it sounds great, I wanted something that gave me a nice full sound and didn't break the bank and I didn't want an amp that took up a lot of room. I experimented with the polyfill in the box a little bit until I got the sub hitting nice and crisp/clean.
  7. Dec 1, 2009 at 7:07 AM
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    Well from what I know, after you extract the bass from your door speakers, they sound so much better. The sub is just to replace the bass the extracted from the door speakers. Since you only want a single 8" or 10", you can use a mono block amp. This means that the amp only has one channel. One channel means that it only has an input for one sub with all the power going to it. Let's say you get an amp with 350 watts rms, you would want to get a sub with 350 watts rms or less. 300 watts rms are good enough to give a good sound. Another thing, in my opinion, brands don't matter for amps although I always recommend Alpine. As for subs, it really matters because of the sound it gives and also the time it lasts. I recommend Kicker for subs. A good sub I used to have is a Kicker Comp VR. It's like $45 from sonicelectronix.com For wiring a mono block amp, purchase an amp wiring kit from walmart that says 380 watts. It costs about $20. It comes with a thick red cable that will go to the "power/battery" part of the amp to your car battery. It also comes with a black thick cable that will go from the "ground" part of the amp to a piece of metal so it can be grounded. Then there's a thin blue cable that goes from the "remote" part of the amp to a blue remote cable on your harness. I don't know if you noticed it had this but if it's already used, just slice into it. The next step is to take the RCA cables that came in the kit, plug them into the subwoofer output on the back of your stereo head unit. If it doesn't have them, you can use the front or rear ones. The other end of the RCA cables will go to your amp and there should only be one set of those so it's easy to find. Then, buy speaker wire and connect the positive cable to the positive input on the amp. Do this again for the negative. You should pretty much be done. By the way, you'll want to run the power cable from the battery through the firewall. The other cables running to the back can be nicely hidden by removing the kick plate and the door sills. Any questions let me know. :)
  8. Dec 1, 2009 at 9:18 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ok so i need a 5 channel amp then. my plans are to have 4 speakers all the same in the doors and in the back (i might upgrade to some better full range speakers later) and one 8 inch sub.
  9. Dec 1, 2009 at 9:25 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  10. Dec 1, 2009 at 10:22 AM
    ENIGMA206
    Palm Bay, FL
    07 4X4 Off-Road DC
    I would suggest that you get either two 8" or one 10". A single 8" is not going to offer much.
    The box for a 10" is not big. They are a dime a dozen...Mr. Marv, Ebay, Best Buy...and so on. The box for two 8" will probably take up more floor space.
  11. Dec 1, 2009 at 10:24 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
  12. Dec 1, 2009 at 10:40 AM
    McJosh
    Josh
    Chandler
    Good deal.
  13. Dec 1, 2009 at 1:58 PM
    DaytonLax14
    DaytonLax14 Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    Get a hifonics amp. Cheap and actually put out the power that they advertise.
  14. Dec 1, 2009 at 2:47 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ok i will keep that in mind but for now i am really considering just and amp then i fill upgrade to some better full range speakers then a sup. so its last on my list.
    whats cheap going to cost me?
    that thing seems pretty powerful, wont it blow out my speakers? (still learning here)
    if anything i think something like this might be my future sub: http://www.tacomaworld.com/forum/audio-video/20413-boss-bass-600-amplified-subwoofer.html
  15. Dec 1, 2009 at 2:57 PM
    07speedwayblue
    07speedwayblue Well-Known Member
    michael
    nineveh, Indiana
    07tacoma sport 4x4 doublecab
    Jason Rage lid, husky floorliners, Procomp 6" stage 1 lift , bilstein 5100 upfront, 33x12.50r17 MT ATZ tires MT 17x9 Classic Locks,stainless steel brake lines,N-Fab ss nerf bars,smittybuilt grille saver, Amp bed extender,Mbrp cool dual t409 exhaust. KCHiLites Daylighter Driving Lights 6", Pioneer AVH-P4300DVD, HD Tunner, Rear Camera, Focal K2 Power 6.5" Component Speakers Front/Back, Infinity Kappa Four and Kappa One Amps, Infinity Kappa 10" DVC Subs,PowerStop Drilled/Slotted Rotors ,PowerStop Heavy Duty Towing Brake Pads, Blue Painted calipers.
    I`ve had good luck with the kicker amps , the quailty is like it used to be. I`m upgraded the amps in my f250 to jl audio. You get what you pay for......
  16. Dec 2, 2009 at 6:55 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  17. Dec 2, 2009 at 6:59 AM
    McJosh
    Josh
    Chandler
    You can get a four channel.
  18. Dec 2, 2009 at 7:01 AM
    tacomarock
    tacomarock Well-Known Member
    I heard a sound system with two PDX amps. pdx 4-100 and pdx 1-600. but now i am thinking about this amp:
    http://www.amazon.com/JL-Audio-Five...1?ie=UTF8&s=electronics&qid=1259755829&sr=8-1
    Only thing is the sub output is 100 watts less than dual pdx amp setup. I was also told that the real wattage on the pdxs will be much higher than rated. I tailgate in ATX so I need a great sounding system in and out of the truck.
    Does anyone have experience with both setups?
  19. Dec 3, 2009 at 7:49 AM
    Mellow
    Mellow Well-Known Member
    Dallas, TX
    08 Ext Cab SR5 4-Cyl Prerunner
    I have an old kicker 652xi amp I think was driving some subwoofers in a truck years ago.. been sitting in the closet for years .. let me know if you're interested in it.. I'm sure it's not worth much.
  20. Dec 3, 2009 at 7:53 AM
    07speedwayblue
    michael
    nineveh, Indiana
