Help me pick out a lift kit!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thatblackyota, May 9, 2022.
  1. May 9, 2022 at 4:08 PM
    Thatblackyota
    Thatblackyota [OP] New Member
    Ollie
    2017 Black Tacoma TRD Off-road
    Mbrp exhaust
    I am looking for a nice 3 inch lift kit but I don’t know if I should get the bilstein combo kit or the dobinsons kit which is a bit more expensive. I don’t plan on doing any crazy wheeling but maybe some light offroading but 90% pavement and I want to be able to fit 285/70/17 on the truck and I already have the rims.
  2. May 9, 2022 at 4:15 PM
    kas2828
    kas2828 Well-Known Member
    Austin
    Arizona
    2020 TRD Off-road 4x4 DCLB
    I would look into keeping it around 2-2.5" on the lift. For your needs, I would look at Bilstein 5100s all around and a AAL in the back. You could spend a lot more on other lifts but I think you will be happy with this setup. Might need a little trimming but will be able to fit 33's. It really depends on the offset of your wheels.
    Thatblackyota[OP] and toku58 like this.
  3. May 9, 2022 at 4:19 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Get the Bilstein 5100's your stock coils from the OR are already 700 lbs. AALs in the rear. it will net a 2" lift and you should be able to fit 285's with minor trimming depending on the wheels you choose? Try and get a set of wheels that have 0 offset or very little negative offset. Should only require minor trimming of plastic to get those to fit.
    Good Luck!
    Thatblackyota[OP] and kas2828 like this.
  4. May 10, 2022 at 8:33 AM
    Thatblackyota
    Ollie
    Mbrp exhaust
    Thanks guys
    kas2828 likes this.
