Help me pick which LT rear
Discussion in 'Suspension' started by byebyebhg, Feb 12, 2025.
  1. Feb 12, 2025 at 6:58 PM
    byebyebhg
    byebyebhg [OP] Well-Known Member
    Lance
    Cloquet, MN
    ‘22 TRD Pro
    I’m not exactly new, but this will be my first time going *kinda* LT
    Just checking to see what I might be missing, and what pros/cons I am looking at given what options we have readily available to us
    Currently running:
    (Front)
    AccuTune re-valved Foxes with my build in mind
    - these were built for when I was running Dirt King factory length uppers and lowers
    Dirk King +2 LT
    - will be upgrading to Dirt King spec Kings and bypasses
    (Rear)
    RXT Option 3
    Archive Garage hammer hangers
    Weight on a daily basis without planning on doing anything fun:
    C4 hybrid full height top tube
    Winch
    RCI steel front skid, aluminum transmission and transfer, steel diff skid
    Outgear Solutions HC Tube bumper w/swingout
    37 and a Hi-Lift on the swingout
    20lb Powertank mounted on the passenger wheel well
    GoFastCamper with probably 50lb inside the GFC TurboCubby on the passenger side
    My RXT pack on Option 3 is pretty flat on this daily setup
    In the near future the daily setup will also include a 270° awning and a shower tent and just might be packed full of everything else for a turnkey weekend trip
    Planning on running:
    JD Fabrication spring under w/HD springs
    https://jdfabrication.com/collectio...ucts/2005-toyota-tacoma-rear-spring-under-kit
    JD Fabrication shock relocate, probably with an angle brace instead of a tube, because our beds are tiny and every inch counts
    https://jdfabrication.com/collections/gen-3-tacoma-16-6-lug/products/rear-shock-mount
    JD Fabrication spec King 2.5 or 3.0 “freebleed” piggybacks because I don’t know what I am doing and hopefully the tires will clear them
    I don’t care about a few hundred dollars difference, is the 3.0 going to be better all around?
    Currently running 37/12.50/17 on Method 701’s with a 2” spacer
    Yeah I hate spacers but have to match the front and it will give me a little more room for shock clearance
    https://jdfabrication.com/collectio...back-free-bleed-shocks?variant=40303017132147
    DMZ frame boxing
    https://dmzfab.com/product/2005-2023-tacoma-frame-boxing-kit/
    I am not sure what to do about bumps yet
    JD Fabrication claims a hydro would cause it to buck, and recommends an Energy Suspension bump
    Pretty sure no Baja race teams use Energy Suspension bump stops, but I am not a Baja race team, just figured if I’m going through all of this, hydros would make sense
    I love the idea of getting rid of the hammer hangers and the brace between them, as I would very much like to use that space for fuel and possibly water storage in the future
    Aside from the Chevy 63 guys, I don’t know of anyone else who does it this way
    Maybe it’s because it is a bad design and I don’t know any better
    ian2016 likes this.
