Help me size my spare tire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iJDub, Jan 18, 2024.
  1. Jan 18, 2024 at 8:26 PM
    iJDub
    iJDub [OP] Well-Known Member
    I have the these TRD wheels on my 2006 4x4 TRD Off Road Double Cab:
    Genuine Toyota Tacoma Bronze 16" TRD Bronze Beadlock Style Alloy Wheel (replaces PTR18-35090-BR) PTR56-35220-F5 | Elmhurst Toyota Parts
    I believe these are the specs: 16-in. x 7.5-in. x 10-mm. six-spoke low-pressure alloy wheels with 5.5-in. (139.7-mm.) bolt circle and 106-mm. center bore.
    I have 285/75/16 tires on them.
    My spare tire is the original steel wheel and I want to get tires that will allow me to have minimal difference between the other wheels.
    Will I have to get new wheels (matching) to get the same offset etc...? or can I get by with the steels?
  2. Jan 18, 2024 at 8:36 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you're asking about a single tire to match the 285s then 255/85/16 should get you fairly close (at least 33"). Anything bigger than that likely won't fit under the bed
  3. Jan 18, 2024 at 10:06 PM
    iJDub
    Will I need spacers when putting it on one of the hubs?
  4. Jan 18, 2024 at 10:15 PM
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    Buy a Matching Rim and start doing a 5 tire rotations. Your Rim is pretty expensive but knowing that you can just swap them out and be on your way is a nice feeling.
    wi_taco likes this.
  5. Jan 18, 2024 at 10:16 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^No. 255/85-16 fits on your factory +30mm offset wheels without spacers.
  6. Jan 19, 2024 at 6:15 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I would use the spare steel wheel I have and find a good used 265/75/16 tire for about $30 to use as a spare. That size is close enough for temporary use.
    I keep plugs, tools, and a small compressor in all of my vehicles. In the last 20-30 years I've only had to resort to the spare one time. I've used the compressor and occasionally the plugs at least 20 times. Mostly to help other stranded drivers. I can almost always just air up a flat and make it to a tire shop and let them fix the problem. In rare cases I may need to resort to plugging the tire. Depending on where the problem is I may leave it, or I may still take it to a shop for a better repair.
    It is a lot simpler, easier, faster, cleaner, and safer to do this than have to put on the spare. I would ALMOST be willing to run without a spare, but I'm not that confident. I did have two incidents where the hole was too big for plugs. Both tires were ruined. One of them took 3 plugs and held air long enough for me to make it a few miles to an exit and a tire shop. They couldn't save the tire, but they put the spare on. The other time I did have to use the spare.
