Help me spend (or not) my money
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cdavis, Dec 10, 2010.
  1. Dec 10, 2010 at 7:30 AM
    Cdavis
    Cdavis [OP] Active Member
    OME 2.5" Front, Rear add-a-leaf with extended shackles, Downey Super-clutch, 33" BFG MT
    So I need a couple of new upper ball joints... Which begs the question, while I'm at it, why not just get some toytech uca's? Anyone have any insight on those specifically? Some moog ball joints are only 40 bucks...
  2. Dec 10, 2010 at 7:40 AM
    Whitfield
    Whitfield Well-Known Member
    Central Virginia
    99 TRD X-cab on 35's / 96 X-cab on 33's
    Selling my 96 Tacoma to fund the FJ80 build up.
    Buyer beware ~ even name brands are having to knock out a CHEAP product competing with the Tawian parts just to stay in business.
    Consider the consequences of failure and buy accordingly.
  3. Dec 10, 2010 at 3:29 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    i assume your talking about the Light Racing UCAs eh? i dont think toytec makes any themselves. try doing a search on the LR UCAs and you will find a tonne of info and opinions on them.
  4. Dec 11, 2010 at 7:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How about some details about your truck and how you use it. Its difficult to give you any meaningful advice without details.
    What year?
    6 lug or 5 lug?
    4x4 or 4x2?
    any lift or plans for lifting?
    Off road much?
  5. Dec 12, 2010 at 10:28 AM
    Cdavis
    Sorry, guess I spaced out on that one...
    It's an '01, access cab, has a 2.5 inch OME lift, with 285's... It has just over 190k and is running well. It's used mostly as a "trailhead approach" vehicle with lots of highway miles, then an 4wd approach to get access for skiing/climbing, etc...
    Basically, the question was is it worth it to just upgrade the UCAs, or just put in some new, possibly beefy-er ball joints and expect them to wear out again?
