Help me understand sr vs others
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oystertaco, May 15, 2024.
  1. May 15, 2024 at 11:26 AM
    oystertaco
    oystertaco [OP] Member
    2020 sx 6cyl 4x4
    I seem to be opening cans of worms here by mistake. I'm just tegularly towing a not so heavy boat (19ft carolina skiff) mostly about 10-15 miles from home and never more than 100. I may get a small pop up in the future and that's a maybe as I prefer to tent on the ground. I don't want to haul 6 tons of gravel!
  2. May 15, 2024 at 11:28 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Reading ahead helps to prepare. If you mostly pull short-range (vs cross-country) and loads in the 1500 lb range, then you can still get advice about "brake controllers" and hitch accessories.
  3. May 15, 2024 at 11:43 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Toyota needs to rebrand their Auto-LSD cause it's misleading considering its very much an open diff.
    That said, aftermarket e locker is easy to swap in for us non TRD OR/Pro folks.
    OP..if you're towing, get yourself a hitch receiver, brake controller and maybe a transmission fluid cooler and hit the road.
    The v6 tacos all haul the same no matter the trim.
    SH10151 likes this.
  4. May 15, 2024 at 11:45 AM
    uhchxrlie
    uhchxrlie Well-Known Member
    2020 MGM Tacoma SR SX Package
    265/75/16 Toyo Open Country AT. Between the tires, the camper shell and all the stuff in the back I only lost 1 MPG.
