Help me understand the manual preference
Discussion in '3rd Gen. Tacomas (2016-2023)' started by angry john, Feb 26, 2016.
  1. Feb 27, 2016 at 8:32 AM
    #61
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    I've never had a battery go so flat I couldn't push start the car. I've never done it on my truck, but I've done it to other, newer vehicles.
    Not disagreeing, but if you're in a pinch, I've never not been able to do it.
    RedBeard1 and tomtom like this.
  2. Feb 27, 2016 at 8:36 AM
    #62
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    The technical part of driving a manual off or on road if the whole fun of it to me. Those white knuckle moments climbing an off camber ledge and catching a lower gear with out rolling back or over in the process is what makes wheeling enjoyable to me. Left foot on the clutch, right heal on the brake, right toe on the gas, one hand on the wheel and the other rowing gears....! That's just what floats my boat. To each his own.
    nevadabugle, Howen, BHill_teq and 2 others like this.
  3. Feb 27, 2016 at 8:37 AM
    #63
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    I haven't either. When I had to push start my first gen at the gas station one morning, the lights were still working, they were just dimmer than usual. Not enough power to crank the engine though.
  4. Feb 27, 2016 at 8:43 AM
    #64
    scocar
    scocar hypotenoper
    Driving versus spectating.
    RedBeard1 likes this.
  5. Feb 27, 2016 at 8:44 AM
    #65
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Alternators are usually ''self exciting'' in that they don't need electricity to produce it, older generators on the other hand do need
    to be ''excited''by applying voltage to them to get them to produce electricity.
    The main computer in most modern vehicles will not operate under 9.2 [off the top of my head] volts as they will be damaged. You also need enough juice to run the fuel pump, anyone who has push started a modern manual transmission did not have a completely dead battery, just one without enough amps to spin the starter.
  6. Feb 27, 2016 at 8:47 AM
    #66
    DanielTaco
    DanielTaco Well-Known Member
    Daniel
    Iceland
    2016 Tacoma DCSB TRD OR 3.5
    You have that backwards.
    StevoNB likes this.
  7. Feb 27, 2016 at 8:51 AM
    #67
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    Looks like you've got a 2000, mine is a 2013.
  8. Feb 27, 2016 at 8:54 AM
    #68
    RedBeard1
    Red
    Possessing the skill set to operate a manual transmission smoothly off road. It is not fighting it is just knowing how to do it correctly. 90% of the time on the trails my crawler is in single low and 3rd gear and I only need the clutch when I come to a complete stop somewhere. Most of the time my left foot is on the foot rest on the wheel tub or on the slider if I have the doors off. I'll say again it is not a fight it is just knowing the limitations and characteristics of both you and your vehicle.
    scocar and Willbeck like this.
  9. Feb 27, 2016 at 9:00 AM
    #69
    StevoNB
    NB, Canada
    That's what I initially thought too, but it seems the alternator needs a small current to its rotor to create electricity. It gets this current from the battery.
    Hondah[QUOTED] likes this.
  10. Feb 27, 2016 at 9:22 AM
    #70
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Maybe it's a reliability thing - that trumps drive abilit when the Engs sit down and design. But if Yota could program in good shift points and programming Id have the Auto.
    when I heard online reviews and people on here saying the same thing "shift happy"confused " transmission about 3rd Gens as I always thought about my 2nd gen- my mind was made up.
  11. Feb 27, 2016 at 9:30 AM
    #71
    CAM37
    CAM37 Well-Known Member
    2016 Black TRD Sport
    Started driving manual transmission cars at age 16 and have owned only 2 automatics in my life, including this truck and the only reason now is because the knees are not so good and there's a lot of stop and go traffic in the DC metro area. But there's nothing like the ability to determine your own shift points each and every time you row through the gears. I've often said that when I drive a stick, I feel like I'm driving but in an automatic, I feel like I'm just a co-pilot and the vehicle is driving itself. Getting older is a bitch but it beats the alternative.
  12. Feb 27, 2016 at 9:30 AM
    #72
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    That's exactly how I stumbled into my truck... well after test driving a Nisan <spit> then the sales Mgr. tried to upsell me a $29K truck for $40k ... meh no thanks. Taco FTW.
    My wife won't drive anything but manual but she's scared to drive my TRD Sport, so far. I much prefer manual to auto - makes me feel more connected to the road and my vehicle, that and I've never had anything but a manual since I learned to drive in the 70s.
  13. Feb 27, 2016 at 9:32 AM
    #73
    DanielTaco
    Daniel
    Iceland
    Wind and hydro turbines use permanent magnet systems, completely different than a car alternator. You absolutely need DC current to excite the rotor in order to generate electricity with a car alternator. You can not bump start a gas engine vehicle without a battery charge. Yes the battery can be weak, but it won't work if it's dead or removed. It will crank, but it will not start because there's no ignition.
    StevoNB likes this.
  14. Feb 27, 2016 at 9:35 AM
    #74
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    False. I tested this out on my 16 and it bump starts VERY easily.
  15. Feb 27, 2016 at 9:45 AM
    #75
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Well, this is getting pretty far into the rhubarb with respect to the the OP's topic, but I will add this -
    You do in fact need a small amount of current to a modern alternator to get it to produce output. The reason? A coil passing through a magnetic field will have a voltage induced in it. And, a coil with current passing through it will produce a magnetic field (like in a relay); Since alternators don't have permanent magnets in them, where does this magnetic field come from? It comes from a coil that already has current flowing through it (form an outside source - the battery).
    AS said above, you may not have enough CURRENT left in your battery to crank the engine, but unless the battery is completely flat you would probably have enough VOLTAGE to get the alternator producing O/P when it rotates - ie from push starting. See the chicken and the egg paradox to this?
    Anyway, you need a small amount of juice in your truck to push start it. Try unhooking your battery and push starting. Bet you supper you'll just tire out your buddies :D
    Frank
    StevoNB likes this.
  16. Feb 27, 2016 at 9:55 AM
    #76
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    I thought this is a different transmission than 2nd gen? I haven't read anything about manual transmission problems with the new 3rd gen's transmissions.
  17. Feb 27, 2016 at 9:56 AM
    #77
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    I am over clutching. My first Vette was a 6 Speed Manual. PIA in light traffic. My second Vette and MX5 are automatics with paddles. Only thing missing is a clutch and I can do without the extra mechanicals from the driver,
    I cannot think of a vehicle I would prefer a manual in.
  18. Feb 27, 2016 at 10:03 AM
    #78
    JoeRacer302
    Joe
    Pasadena, CA
    1997
    Willbeck likes this.
  19. Feb 27, 2016 at 10:08 AM
    #79
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    I like my manual on icy roads around town. I can slip the clutch a little more and keep my wheels from spinning when I'm starting out at an icy intersection.
  20. Feb 27, 2016 at 10:26 AM
    #80
    Hondah
    Newnan, Ga
    '13 RC 4x4
    I stand corrected. I just read for like an hour trying to tie up my loose ends of knowledge, plus watched several YouTube videos. Thanks for your input and clarification.
    Conclusion is, as along as the coils are "excited" then the alternator will provide electricity. So given each circumstance, if one can do that, they can get on their way. :thumbsup:
