Help me wire squadron sports from Baja design.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krs1760, Apr 19, 2017.
  1. Apr 19, 2017 at 4:30 PM
    Krs1760
    Krs1760 [OP] Well-Known Member
    Kyle
    San Diego
    07 4x4 taco silver baja bitch!
    2.5" fox coilovers w/remote resivour, tc uca's, 2.0" fox piggy backs, allpro exp leaf packs timbren bumps, pelfrybuilt front bumper with smittybuilt xr -20 winch with 20" bar behind grill. More lights to come with armor. 1999 pop up in the bed
    I have no more fuses so off to the auto parts store. What size should I get? Any reason it would blow? I did nothing out of the ordinary so clueless at this point.
  2. Apr 19, 2017 at 4:33 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Don't get a larger fuse! That's a 15A fuse which would be good for over 150W at 12V. You are trying to drive 20W, 40W for the pair - so just 3A. You are pulling more than 5 times the expected load. So something is shorted some place. You'll need to find the short.
  3. Apr 19, 2017 at 4:33 PM
    Hennessy
    Hennessy Well-Known Member
    Charlotte NC
    13 Red DC TRD Sport
    Demello Baja bumper, Mcneil Fiberglass, Fabtech Uniball Upper Control Arms, Emu Dakar leaf springs, Fox 2.5 Factory Series Coil-over IFP, Fox 2.0 Performance Series IFP
    there should be no reason to go larger, the only thing I can think of is the hot wire grounded out somewhere
  4. Apr 19, 2017 at 4:44 PM
    Krs1760
    Kyle
    San Diego
    How would I go about finding the short? The two looms from the fog light marry into what I'm guessing is the head lights then to the fuse box. It's one big loom tucked away under the battery.
  5. Apr 19, 2017 at 4:49 PM
    Hennessy
    Charlotte NC
    13 Red DC TRD Sport
    before you start digging into the wiring loom just change the fuse and re-wire the lights and check if the fuse blows again. start simple..
  6. Apr 19, 2017 at 4:51 PM
    Krs1760
    Kyle
    San Diego
    Sounds good I'll start there and check back in with results. Thanks for the help hope it's nothing major
  7. Apr 19, 2017 at 9:20 PM
    Krs1760
    Kyle
    San Diego
    Ok so picked up a box of fuses and wired the lights upon a little trouble shooting there is two wires a white and a green. The green is the hot and that explains why they burned out cuz I had white on white which actually was -/+ future reference the green wire is the +. Thanks for all the help the lights are bright as all hell
    DVexile likes this.
  8. Apr 19, 2017 at 9:38 PM
    DVexile
    Ken
    Awesome, glad you got it sorted and only lost a fuse and little bit of your time!
  9. Apr 20, 2017 at 8:50 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    When wiring to the factory fog connection please be sure to confirm Positive and Negative polarity before installing. If wired incorrectly the lights will blow the OEM fuse. Toyota can be a little inconsistent so it's better to fully check before crimping all the connectors or soldering the leads together. Our lights have the following wiring layout (White = Positive Current + , Black = Negative Current). It looks like they were most likely wired incorrectly and the factory fuse was blown. Our lights do have reverse polarity protection to help prevent damage to the light if the wires are reversed. If I remember correctly, the factory fog wiring is (Green = Positive Current + , White/Black = Negative Current)... Like I said Toyota can be inconsistent between years and models so I would double check before fully installing.
    -Bailey, Baja Designs
    bailey@bajadesigns.com
  10. Apr 9, 2018 at 4:20 PM
    Sergio W
    Sergio W Well-Known Member
    Sergio
    Lafayette CO
    2015 TRD PRO
  11. Apr 9, 2018 at 4:55 PM
    Falconsfan
    Falconsfan Well-Known Member
    2017 sr dcsb v6 4x4 black
    Are you replacing the factory fogs with these or adding them? If they are additional, get a relay harness($10 bucks on Amazon) and wire the trigger wire to the positive side of the factory fogs. If you are replacing the factory ones, then wire them first with lights and switch off(maybe even battery disconnected) and after both are wired up then put new fuse in and try them, idk why led fogs would be pulling more amps than incandescent bulbs, but larger fuse is almost always a bad idea you might get away with going from say a 5 amp to a 7.5 amp but they are designed to protect the circuit so it was determined that the circuit can handle x amount of amps for a reason and could be a fire if you go larger.
