help me with appropriate tires and wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by bigrooster, Mar 24, 2011.
  1. Mar 24, 2011 at 9:04 AM
    bigrooster
    bigrooster [OP] Member
    frank
    FC
    00 taco ext sr5 Blue
    i have a 2000 black taco ext cab 2.7 sr5 automatic. i just put 2.5inch leveling strut spacers and 1inch blocks in the rear. please help me with a simple but great looking tire size with a cheap black steel wheel size. i would appreciate any comments thank you.
  2. Mar 24, 2011 at 9:06 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    33x10.5x15 on black steelies.
  3. Mar 24, 2011 at 9:35 AM
    bigrooster
    frank
    FC
    the leveling kit is from ready lift and they said only 32's. can you recommend an online dealer. do i have to re-gear anything also. cuz im trying to avoid that.
  4. Mar 24, 2011 at 9:56 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I have a 3" lift with 285/75/16's which is about a 33x11.5. I got my tires from tirerack and i got my wheels from summit. And as far as regearing goes, it depends on your motor. I have the v6 and it does fine with stock gears, but if I had the 4 cylinder I would probably regear just to gain back the lost power. You don't need to regear it though.
