Help! Mechanical Click Under Engine Cover - Truck won't start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Yellow Dart, Jan 1, 2013.
  1. Jan 1, 2013 at 3:40 PM
    The Yellow Dart
    The Yellow Dart [OP] Well-Known Member
    Nick
    Seattle
    07 //SR5 4x4
    OME 2.5" Lift, TC UCAs, LEER Cap, Sleeping platform, PA20-TOY
    Okay, I'm in need some some help. I've tried searching the forum, but my problem seems pretty specific, and I'm not sure of the terminology to parry it down to the right search parameters.
    On to the problem:
    Went out to start the truck this morning - it was about 35 degrees with light frost. After turning the ignition, the starter didn't turn and the there was a loud, repetitive clicking from behind the instrument cluster. Power worked fine - all windows, radio, etc., worked.
    Tried again this afternoon, and it did the same thing in 50 degree weather. Despite all indications it wasn't battery, I tried jumping it, but that didn't work.
    Guy at O'Reilly thought it might be a relay, so I checked all of those and the fuses -- all fine.
    When the GF turned the ignition while I was looking under the hood - the clicking sounded more mechanical and less electrical that when I was in the cabin, and also seemed to be coming from under the engine cover, down near the firewall. This is as far as I've gotten.
    Any help determining this problem would be appreciated. Thanks!
  2. Jan 1, 2013 at 4:35 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Maybe starter. Try and take something and peck on your starter. So you did try to jump? Maybe try a deffrent set of cables and/or make sure you had them hook to battery's good.
    Good luck
  3. Jan 1, 2013 at 4:38 PM
    walterandcarol
    walterandcarol New Member
    walter
    new jersey
    Bang on the starter!
  4. Jan 1, 2013 at 4:38 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    You have an 07. Does it have the original battery? If so, 5 year batteries generally last about 5 years. Buy a new battery.
  5. Jan 1, 2013 at 4:43 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    I have a 09 sport and have already replaced battery in it!
  6. Jan 1, 2013 at 4:46 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Battery or dirty connection. The clicking is the starter solenoid.
  7. Jan 1, 2013 at 4:48 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Millertime; nice Truck! ^^ WOW.
  8. Jan 1, 2013 at 4:51 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Yep. Sounds like the starter. Try hitting it with something as previously suggested. Mine did the same thing when it started to go.
  9. Jan 1, 2013 at 4:54 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Thanks man!
  10. Jan 1, 2013 at 4:58 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Sounds like you know. Thanks for the heads up.
  11. Jan 1, 2013 at 5:16 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Had the same issue on my old 98 turned out to be the altenator...it even clicked rapidly when the new one was installed the first couple times of trying to turn over the engine why jumping...just needed a good ground on the jumpers some more juice and it fired right up...
  12. Jan 1, 2013 at 5:26 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) If your battery is still the original,it may be the problem. You can test it by doing this, turn on your headlights and have someone watch the headlights. Then crank the engine with the headlights on, and if the headlights dim or go out, your battery is bad. If the lights stay lit and do not dim, then the starter relay or the starter is bad. Good Luck.
  13. Jan 1, 2013 at 5:30 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    X1, just replaced mine and it was working fine.
  14. Jan 1, 2013 at 5:30 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    You can also take the battery to a local advanced and they can tell you if it bad or not.
  15. Jan 1, 2013 at 5:32 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    also good to check the terminal connections on the battery, ground, and starter. Had the same issues on a few cars and a wire brush fixed the problem.
  16. Jan 1, 2013 at 5:51 PM
    Blygy
    Blygy Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    Did you jump to the battery or to the starter???
  17. Jan 1, 2013 at 6:21 PM
    The Yellow Dart
    Nick
    Seattle
    07 //SR5 4x4
    Okay, problem solved.
    It WAS the battery. At first I thought it wasn't because the power worked throughout the vehicle and I even tried jumping it to no success.
    But then, just for due diligence, I unhooked it again and took it to O'Reilly to get it tested - figured I'd completely eliminate it as a reason. Turns out it was bad.
    Just got a new Die Hard from Sears.
    I'm pretty sure that it was the original battery -- which is awesome. For what it's worth, my truck was running a Group 27F battery. The Sears guy said he's only seen those in Land Cruisers and whatnot.
  18. Jan 1, 2013 at 6:36 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    98% of the time it's the battery. It doesn't mean anything if your accessories and lights still work. If there is a dead cell your car will not start. Even trying to jump the battery won't work.
  19. Jan 1, 2013 at 7:24 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Cold weather kill a failing battery.
  20. Jan 1, 2013 at 7:33 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Yeah, a typical battery usually last 4 - 5 years.
