HELP: Misfire after plug change
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco.VR4, Nov 11, 2011.
  1. Nov 11, 2011 at 8:33 AM
    Taco.VR4
    Taco.VR4 [OP] Fast Cars, Off-Road Trucks, and Hott Women ;)
    Jay
    Grand Rapids, MI
    '02 Tacoma, '97 3000GT
    5100s, Icon 3 AAL, Custom-built front/rear bumpers, Hybrid seats, 3000GT modified intake box, toolbox, D-rings
    I replaced the spark plugs recently. Had autolites in it, so I replaced with the proper Denso duel-electrode style plugs. I gaped them at 0.40. I also disconnected the negative side of the battery. Started getting misfire while idling @800rpms.
    I took the plugs back out and re-gaped them to ensure they were within spec but no luck.
    On a good note, no negative signs on the plugs (lean/rich/fouling)... but thats only after ~500 miles.
    Ideas??? :confused:
  2. Nov 11, 2011 at 8:34 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Did you forget to plug the harness back in to one of the coils by chance?
  3. Nov 11, 2011 at 8:44 AM
    Taco.VR4
    Jay
    Grand Rapids, MI
    I doubt it but I will doubt-check. So far any other RPM is not affected, only at idle.
  4. Nov 11, 2011 at 11:23 AM
    thatSchusterguy
    thatSchusterguy Common Sense Ninja
    Cincinnati, OH
    96 X-Cab
    OME/881 Downey Shackles Bilstein 5125's Demello HD sliders Marlin 1200# Clutch
    I'm having a similar issue, except mine is only when it's a cold start...
  5. Nov 11, 2011 at 11:30 AM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Check your wires?? sounds like you have something going to ground like a arc. .
  6. Nov 11, 2011 at 11:38 AM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    I would check the plug wires on the drivers side. There might be one that isn't seated well on the plug or the plug wire itself has issues. I had something similar early this year. I changed the plugs and noticed a misfire, pulled the plug wires and tested the resistance and found one that was 4x the specified resistance, if I bent the wire trying to get the Fluke probe into it I noticed that I had an open. There was enough voltage to bridge the gap in the open wire and in doing so there wasn't enough voltage to create a spark on the plug.
  7. Nov 11, 2011 at 12:57 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Could be a bad wire, & the plugs are pre-gapped , usually if electrical the miss will be the same thru out RPM range & won't matter if its been running or just starting up cold, if its electrical a misfire will be there right from the startup...;)
