HELP: Misfire Cylinder 3 (3.4L V6 PreRunner)
Discussion in 'Technical Chat' started by BurgerTaco, Feb 10, 2014.
  1. Feb 10, 2014 at 3:56 PM
    BurgerTaco
    BurgerTaco [OP] Burger Slinger
    Redlands, CA
    04 Xtra Cab PreRunner
    Ok boy & girls, I need your help to figure out WHY I can't get rid of this issue...
    The Truck:
    2003 PreRunner XtraCab (3.4 V6)
    91,000 Miles
    K&N Cold Air Intake
    MagnaFlow Cat-Back
    The Problem:
    Misfire: Cylinder 3
    Started around 80,000 miles
    What I've Tried So Far:
    -Cleaned/serviced Air Filter
    -Cleaned MAF Sensor
    -Replaced all plugs (with OEM Denso's from Dealership)
    -Swapped Coil Packs (in hopes the misfire would jump to another cylinder)
    -Replaced all injectors (with OEM units from Dealership)
    -Added SeaFoam to Gas tank (on multiple occasions)
    -Checked plugs after new injectors were installed (clean)
    Each step I tried yielded the same results;
    Engine ran smooth for a bit (never more than a day) followed by the CEL: P0303
    I've always been on top of suggested maintenance, either personally or handled by the trusted mechanics who work next door. I never run anything less than 89 Octane (Mostly Chevron, with the occasional Shell visit).
    PLEASE HELP!
