HELP! Missing nut for lower strut assembly bolt
Discussion in 'Suspension' started by Zombie Runner, Mar 30, 2012.
  1. Mar 30, 2012 at 10:56 AM
    Zombie Runner
    Zombie Runner [OP] Are these black helicopters for me?
    Kevin
    Wichita Falls, TX
    Tundra, double cab.
    LED interior lights, stubby antenna, Pioneer in dash screen, good driver mod.
    I might end up buying a digital caliper in the process of all this :D
  2. Mar 30, 2012 at 10:57 AM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+250k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Ok, the nut just got more expensive. *snicker*
  3. Mar 30, 2012 at 11:00 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    This.
  4. Mar 30, 2012 at 11:00 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    Tundra, double cab.
    When I was making this thread I almost titled it " Nut help" or "Help, lost nut" :anonymous:
  5. Mar 30, 2012 at 11:14 AM
    TacoCat
    TacoCat Look away, I'm hideous!
    Johnny-5
    Chantilly, VA
    Silver 2010 OR
    That happens when you say "I do"
  6. Mar 30, 2012 at 11:17 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    Tundra, double cab.
    lol but then it would have to be plural "nuts"
  7. Mar 30, 2012 at 11:20 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    :rofl:
    This made my day
  8. Mar 30, 2012 at 11:55 AM
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    duct tape
  9. Mar 30, 2012 at 12:04 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    Tundra, double cab.
    there i fixed it
  10. Mar 30, 2012 at 12:27 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    So did you get your nuts back?
  11. Mar 30, 2012 at 12:40 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    Tundra, double cab.
    I have one left. Hopefully lowes will be able to help me out with my missing nut
  12. Mar 30, 2012 at 12:51 PM
    Pugga
    Massachusetts
    F-150 Mod
    FWIW, I lost a nut off something for my shell and I went to a small local hardware store. The guy grabbed a handful of nuts and we went to the parking lot til we found the one that fit. Sometimes the smaller shops are much better to deal with for stuff like that.
  13. Mar 30, 2012 at 12:53 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    why not? hell I would do it if I had 2. I cary a bag full of grade 8 nuts/bolts/washers just in case something like this were to happen
  14. Mar 30, 2012 at 12:57 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Because standard won't go on metric threads and it will only make things worse
  15. Mar 30, 2012 at 1:32 PM
    #35
    Zombie Runner
    Kevin
    Wichita Falls, TX
    Tundra, double cab.
    im just gonna try a few different 19mm nuts and hope I get lucky.
  16. Mar 30, 2012 at 2:00 PM
    #36
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Im pretty sure 19mm is the socket size, not the size of the thread. A 19mm shaft/thread would be huge
  17. Mar 30, 2012 at 2:21 PM
    #37
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    *snicker*
  18. Mar 30, 2012 at 3:23 PM
    #38
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    The nut for this bolt is the same as the nuts on the bottom of the trailer hitch (if you have the tow package). The bolts that connect the stock rear bumper to the hitch. The top of the bolt is covered by the plastic cap on the bumper.
    Last year at a meet we noticed someone missing that same nut. We were able to remove the nut from the hitch receiver and use it since we were not towing anything.
  19. Mar 31, 2012 at 1:45 AM
    #39
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    I've used bailing wire to wrap around a bolt and then pinch it closed, kinda acts like a nut. Good enough for a temp fix.
    Lost the nut off passenger side front spring hanger bolt one time. Found another random metric nut that fit. Probably the same thread as the shock bolts. You'll find one.
  20. Mar 31, 2012 at 7:10 AM
    #40
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    I had the same thing happen. Its fine to drive on it...I think I went like 3 months before I even noticed it was missing. Local Firestone put a new nut on there for free
