HELP! Missing nut for lower strut assembly bolt
Discussion in 'Suspension' started by Zombie Runner, Mar 30, 2012.
  1. Mar 31, 2012 at 7:35 AM
    #41
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Now that's good information to know! :thumbsup:
  2. Mar 31, 2012 at 7:50 AM
    #42
    medic2230
    Murph
    Bama! Roll Tide
    I was about to say there has to be a nut on the truck somewhere that will fit it that you can go without for a little bit. That would have been my first place I looked. :)
  3. Mar 31, 2012 at 8:18 AM
    #43
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Well if you don't get it figured out I've got a shit ton of them here I could send one out.
  4. Mar 31, 2012 at 10:25 AM
    #44
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Take the other nut from the opposite side, go to a hardware store, put it on one of the little thread finder displays and figure out what its pitch/count is. Buy a grade 8 nut to replace it. If not, I cannot recommend it, however any grade nut should be able to do a 'temporary' job... do not offroad etc... until your dealership gets one in stock. The strain is on the bolt, not the nut. Don't overtorque and put a little blue loctite for security.
  5. Mar 31, 2012 at 8:56 PM
    #45
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    10.9 bolt not grade 8. Grade 8 is standard. 10.9 metric. I think that bolt may be 8.8. Either way go to Home Repo and buy one to hold you over till the dealer gets the right bolt in stock. Do not zip tie.
  6. Apr 2, 2012 at 6:14 AM
    #46
    Zombie Runner
    Zombie Runner [OP] Are these black helicopters for me?
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    thanks for all the replys everyone. I went to lowes and auto zome and neither had the size I needed. I ended up getting a smaller version of what was already on there to hold me over. Ill be getting my nut from the dealer today hopefully :D
    P.S. thank you to the mod that edited my title :)
    +1 to DB
  7. Apr 1, 2023 at 4:20 PM
    #47
    CATSNKE
    CATSNKE New Member
    2013 DCSB TACOMA PRERUNNER
    Lifted bilsteins old man emu pak
    Super old post but because it’s the first one that showed up in Google and I had the same problem and i the sorted out it at Ace Hardware. The correct nut is the M 14 1.5 pitch threads. This will at least get it and get back on until you can get a factory replacement.
  8. Apr 2, 2023 at 6:16 PM
    #48
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    I believe Its m14 x 1.5
    Not 1.75
  9. Apr 3, 2023 at 6:17 AM
    #49
    CATSNKE
    CATSNKE New Member
    You’re right I edited my post.
    JFriday1 likes this.
