[Help] - Mounting Pods
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scoobarooo, Mar 11, 2016.
  1. Mar 11, 2016 at 4:54 PM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Basically I'm trying to install these pods.
    I really want them them behind my bumper like the first picture so it's harder to steal or see them.
    I don't how to make to a mount to mount it where it is in the first picture picture. If someone with a 1st gen could take a look at their truck and see if they see a way I'd appreciate it. Or if someone's already done it that'd be even better
  2. Mar 11, 2016 at 5:28 PM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    Do you have any fab skills? I had my local shop make me some simple brackets that i just bolted in behind my grille off the rad.support
  3. Mar 11, 2016 at 7:08 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    I've learned here and there from watching and helping friends. Not nearly enough to do anything myself though. And I'm not properly equipped to do anything like that.
  4. Mar 11, 2016 at 7:33 PM
    westhumboldt
    westhumboldt Well-Known Member
    Arcata,Ca
    97 Tacoma sc 4x4
    Doug Thorley headers, urd 7th and Trd Supercharger, bilstein lift, trd locker just installed.
    if you got some spare thin steel just cut/bend a bracket up real easy if have a few tools
  5. Mar 11, 2016 at 7:56 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    I used a dremel to cut the plastic so i could mount the pods upside down in that spot. Mounted to the bottom of the steel bumper. Looks like upper lip of plastic is thicker on 01+ so you could bolt some 1" channel to steel bumper then mount the pods upside down to that.
  6. Mar 11, 2016 at 11:44 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    You could do so.ething like I did for my 20". Requires a drill, vice, hammer, hacksaw. And perforated flat stock pieces cut down to whatever length. You could do a whole section like I Did. Maybe an extra support bracket in the middle going to the radiator support to help it be more sturdy. Or two small sections attached to those tabs in valence alone. There's other ways too I'm sure. Just an idea. But anything custom like this is gonna require some creativity, and some tools. Unless you have someone else do it for you. I lost access to tools I had so I had to go buy all the mentioned tools I used. Harbor freight has cheap stuff and fair quality. Ace hardware for the other supplies like bolts and steel. IMAG1604.jpg IMAG1607.jpg IMAG1606.jpg
  7. Mar 13, 2016 at 4:42 PM
    NightProwler
    Harlan
    Maricopa, Az
    Could always do what this guy did. Just saw this. Mount them directly to th3 plastic. But they'd probly be super wobbly.
  8. Mar 13, 2016 at 6:07 PM
    NightProwler
    Harlan
    Maricopa, Az
    Then there's this method too I recently found on here. In considering changing to this method eventually. Hoping it'll make my light more secure and sturdier. Still got a little shake on mine on bumpy roads. Could do these L brackets with long ubolts. Then attach a beam across and mount your pods to that. That way you can adjust the depth. Probly be fine with just one ubolt each side.
