HELP!!! My 2015 automatic won't go into gear!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SoCal_Yotas, Dec 27, 2015.
  1. Dec 27, 2015 at 5:30 PM
    SoCal_Yotas
    SoCal_Yotas [OP] Well-Known Member
    Elias
    Santa Clarita
    2015 Toyota Tacoma TRD-Sport 4x4
    My 2015 won't go into gear it was working before and now 15 minutes later it's not its in park but it won't let me put it in gear also none of the gear lights on the dash are on not even the park light. What's wrong with it?!?!? I was trying to install some Aux reverse lights on my rear bumper and tapped into my reverse wires but idk if that could have done it?
  2. Dec 27, 2015 at 5:31 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Did you check any of the fuses that would be related to what you were working with?
  3. Dec 27, 2015 at 5:40 PM
    SoCal_Yotas
    Elias
    Santa Clarita
    No I haven't could that be the problem? I'll check my fuses
  4. Dec 27, 2015 at 5:42 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    99% chance u blew a fuse
    Fenwick1993 likes this.
  5. Dec 27, 2015 at 5:42 PM
    tacobell007
    Drew
    Western MA
    What Rock Lobster said if you need to move it. I would start by checking fuses, even ones you don't think would have anything to do with the reverse lights. It's the easiest thing to check first
  6. Dec 27, 2015 at 5:47 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Probably grounded the brake light wire by accident. Verify your brake lights aren't working? If they are not working, check the 10A fuse labeled "STOP" in the fusebox under the hood. If the fuse is burnt, no current flows through the brake pedal switch, which supplies a signal to the shift lock ECU to release the shift lock.
    Fenwick1993 and Nickel like this.
  7. Dec 27, 2015 at 5:49 PM
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    I would try the above and possibly undo what you you touched wiring if immediately after it wouldn't shift.
  8. Dec 27, 2015 at 5:54 PM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    Shifter won't move unless you are pressing the brake pedal down.
    The signal that the brake is pressed is the same circuit as the brake light.
    Doing electrical work without the battery disconnected can result in grounding a power lead and blowing a fuse.
    No signal from the brakes because the fuse is blowed up good means no shifty.
  9. Dec 27, 2015 at 6:00 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    blowed up real good
    jmaack, tacobell007 and Fenwick1993 like this.
  10. Dec 27, 2015 at 6:00 PM
    SoCal_Yotas
    Elias
    Santa Clarita
    Thanks everyone it was a fuse luckily!!!!
    tacobell007 likes this.
  11. Dec 27, 2015 at 6:26 PM
    KenLyns
    Belly of the Beast
    ^Which fuse was it? Now keep an eye on it.
