Help... my 2019 Tacoma not lighting the trailer brake lights...
Discussion in 'Towing' started by Vinny68, Jul 31, 2020.
  1. Jul 31, 2020 at 2:42 PM
    Vinny68
    Vinny68 [OP] Member
    Tom
    Red 2019 SR5
    Dual dash cam, interior LED lights, tag lights, reverse lights, mud flaps, running boards
    When I first purchased the Tacoma, the trailer brakes lights worked fine. Now for some reason, the trailer brakes lights will not work. It is not the trailer... because I have now towed 4 different trailers with the Tacoma, two with the five pin connector and two with the seven pin connector... No trailer brake lights. Is there a specific fuse for the trailer brakes and if so, where exactly is it located. Thanks
  2. Jul 31, 2020 at 5:24 PM
    Vinny68
    Vinny68 [OP] Member
    Tom
    Red 2019 SR5
    Never mind... I found the problem. It was the main 25 amp "Towing" fuse in the panel under the hood. :)
  3. Feb 8, 2025 at 10:19 AM
    rfreynol89
    rfreynol89 Member
    Rob
    2019 TRD Pro
    Same problem. There were no blown fuses, checked towing fuse (25a) in the engine bay, and the 7.5 in the cab, too. Changed the towing relay and the 40a battery charger fuse (it was blown)—still no brake lights or turn signals. Running lights and trailer brakes work fine. I tried with two different trailers (7-pin) and a 5-pin tester.
  4. Feb 11, 2025 at 5:38 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The trailer brake and turn signals are controlled by the Combination Meter (Instrument Cluster), unfortunately it's not uncommon for a short on a trailer to blow the circuit in the meter. Poor engineering on Toyota's part but do check wiring integrity before condemning the Meter.
    Also a PSA to anyone with a 3rd gen I would highly recommend replacing the TOWING Fuse (25A) with a 15 amp or less fuse to hopefully protect the circuit in the Meter, it's not uncommon for a trailer short to take out the vehicle turn signal drivers in the Meter as well. You want the fuse to blow before the drivers in the Meter fry.
