Help, my alternator went out after a day of mudding
Discussion in '1st Gen. Tacomas (1995-2004)' started by Von Himmel, Jul 9, 2012.
  1. Jul 9, 2012 at 2:48 PM
    Von Himmel
    Von Himmel [OP] Active Member
    James
    Pendleton
    01 TRD SR5
    I went off roading pretty hard in my stock 01 TRD SR5 and my battery light went out. I replaces the alternator with a used one and hit the puddles again, and it went out again. Should I replace it and stay out of the mud or... what?
  2. Jul 9, 2012 at 2:51 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    welcome to tacoma world. i have no idea but someone should stop by soon and tell you.
  3. Jul 9, 2012 at 3:10 PM
    Von Himmel
    James
    Pendleton
    01 TRD SR5
    I have all of my stock splash guards in place, The engine bay is coated though. Does anyone make a shroud to keep it clean and dry?
  4. Jul 9, 2012 at 3:13 PM
    donaldwagner
    donaldwagner -Don-
    Donald
    College Park, Orlando
    2013 single cab 4x4
    mudding takes its toll on vehicles, do you have a warranty on that alternator? check your battery relay/fuse also. Autozone or Advanced can check your alternator for you, dont tell them it's because of mudding. And when if you buy one from them it comes warrantied so next one is free
  5. Jul 9, 2012 at 3:44 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Yeah, when muddy water gets into a motor or alternator, it can ruin it.
    Stay away from mud, if you don't want the expense. You may be able to fix it by taking it apart, and cleaning it. (Toyota OEM alternators are expensive).
    Its too bad that Toyota designers decided to mount the alternators down low, instead of up high. Makes them very vulnerable during water crossings and mudding. Mudding is fun, but not worth it, if it costs over $300 when (and if) you get home.
  6. Jul 9, 2012 at 5:49 PM
    Von Himmel
    James
    Pendleton
    01 TRD SR5
    How does one clean an alternator? I ve ead that you can bring the vehicle to a DYI car wash and use the pressure washer, true?
  7. Jul 9, 2012 at 5:50 PM
    Von Himmel
    James
    Pendleton
    01 TRD SR5
  8. Jul 9, 2012 at 6:05 PM
    extremepaint
    extremepaint Well-Known Member
    denver
    04 with stuff
    Its pretty simple pull off the end cap amd clean the brushes u can pull it down evene farther and clean the bearings and armature but most of the time its just the brushes get stuck with a little bit of grit. U can use a small amount of grease on the side of the copper brush to keep them from sticking so quick. Ur old alternator is probally fine . Clean it test it and resell it if it didnt get used as a core. Also ne carefull with the ceramic endcap its pretty fragile. Should take u more than 15 min once u have it out
  9. Jul 9, 2012 at 6:08 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    You're sure its the alternator? Check all the body grounding points; 9x out of 10 a ground is corroded off somewhere. Also, 5 year batteries generally last about 5 years.
  10. Jul 9, 2012 at 7:12 PM
    Von Himmel
    James
    Pendleton
    01 TRD SR5
    I am pretty sure its the alt, I took it to Les Schwabs and they tested it and said it wasnt putting out any charge at all
  11. Jul 9, 2012 at 7:13 PM
    Von Himmel
    James
    Pendleton
    01 TRD SR5
    I hate to sound like a noob, but will this tear down require any special tools? Any special cleaning agents involved?
  12. Jul 9, 2012 at 7:15 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    If its dead you'll need a rebuild kit; I don't think cleaning it will help. I'd get a rebuilt alternator from PEP Boys or someone reputable. Don't dick with it. At the end of the day it's not worth it. $128.99 at Pep Boys.
  13. Jul 10, 2012 at 12:36 PM
    Von Himmel
    James
    Pendleton
    01 TRD SR5
    Problem solved, I guess I just had to pressure wash it out
  14. Jul 10, 2012 at 1:46 PM
    extremepaint
    denver
    04 with stuff
    Im pretty sure its a small hex head and some phillips to pull the end cap and clean the brushes. Ive done it 2-3 times its easy stuff and saves u a load of money
  15. Jul 10, 2012 at 9:28 PM
    tan4x4
    Rick
    Folsom, CA
    So .... you took it to a car wash and pressure washed the alt? This fixed it?
  16. Jul 11, 2012 at 8:38 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
  17. Jul 11, 2012 at 11:26 AM
    extremepaint
    denver
    04 with stuff
    When ever working on any electrical components its best to disconnect the battery. The electronics parts washer will be fine. Its the same thing as servicing an r/c body car motor. Take it apart clean it lube the obvious things and youll be good to go. Just make sure your brushes are making contact with the commutator and the copper is clean and shiny.
  18. Jul 11, 2012 at 11:37 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    You mudder guys need to install water cooled alternators!
  19. Jul 11, 2012 at 11:38 AM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Link.... Link now please
  20. Jul 11, 2012 at 12:01 PM
    HBMurphy
    Paul
    So California Coast
    None
