Help my fix my office door handle!
Discussion in 'Off-Topic Discussion' started by Ghost., Dec 2, 2014.
  1. Dec 2, 2014 at 1:27 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yep , that's pretty standard
  2. Dec 2, 2014 at 1:30 PM
    Ghost.
    Ghost. [OP] TW 1%er
    Raymond
    Anchorage, AK
    4runner, Taco, GX460, Tundy
    [Beavis;9516431].................................................[/QUOTE]
    I've pounded it plenty
  3. Dec 2, 2014 at 1:31 PM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    hmmm.... have you tried turning it off and back on again?
  4. Dec 2, 2014 at 1:32 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Sometimes if you push the middle section in with a pen it releases it. I recall an office door at my old work having something similar. Where you could lock the mechanism in by pushing it further than 'flush' with the door edge. Idk if it makes sense but try pushing the parts, is there any play in it? Or does it feel jammed?
    Ive looked it up a bit, its an L series from Schlage but nothings in the manuals shows troubleshooting. The hole on top of the latch is the pivot pin for the 2 pieces. the center piece moves independently of the upper/lower pieces. If you look close enough the middle piece has a cutout and a lip. I believe that is what's holding it in. Maybe try pushing on it while depressing a door handle? Idk what else if you've already given it a few good whacks.
  5. Dec 2, 2014 at 1:35 PM
    wtjl240
    wtjl240 Well-Known Member
    Jeff
    Spring Hill, TN
    Grasping at straws here... When you get a screw driver, take that plate off. My door looks just like that, however, I have a switch below there so I can keep it locked or in place. Maybe they replaced the plate for the one you have and the switch is behind it :notsure:
  6. Dec 2, 2014 at 1:37 PM
    Ghost.
    Ghost. [OP] TW 1%er
    Raymond
    Anchorage, AK
    It feels like it is in there solid
    I don't have a screw driver, I would have to grab one from home tomorrow
    I think there is a pin in there holding it back but I don't know how to release iT
  7. Dec 2, 2014 at 1:39 PM
    Crusher 2
    Crusher 2 Well-Known Member
    N. Virginia
    19 DCSB, SR5, Cavalry Blue, mostly stock
    OK finally somewhere I can chime in.... I'm a commercial building engineer. That's a Schlage L series Mortise lockset. Remove the two Phillips head screws holding the plate on the edge of the door... that may be enough to release the bolt. Mortise lockset inside the door may be off center. big screw driver slid in beside it will adjust. re-install the plate on the edge of the door. Has nothing to do with the holes in the handles. those are for a spanner wrench used to remove the handles.
    Chuck
  8. Dec 2, 2014 at 1:39 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    +1 sir.
  9. Dec 2, 2014 at 1:40 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
  10. Dec 2, 2014 at 1:41 PM
    Ghost.
    Ghost. [OP] TW 1%er
    Raymond
    Anchorage, AK
    i will grab a screwdriver tomorrow and bring it to work
  11. Dec 2, 2014 at 1:41 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    :thumbsup:
  12. Dec 2, 2014 at 1:45 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    How many TW members does it take to fix a door?
    Ghostperiod, I'm rather disappointed that you don't keep basic tools in your office, and that this door is even still on it's hinges and not being secretly swapped out with a mean coworker's during lunch break
  13. Dec 2, 2014 at 1:46 PM
    OZ-T
    Peter North
    British Columbia
    So it's not a multi function mortise set like the type where you push in to keep it from locking ?
  14. Dec 2, 2014 at 1:49 PM
    Crusher 2
    N. Virginia
    No not unless someone has installed the wrong cover plate.
    Look closely at the center strike (of the three piece strike) the center is rolled out of position. removing the plate should allow it to return to normal position.
    Chuck
  15. Dec 2, 2014 at 1:53 PM
    #35
    OZ-T
    Peter North
    British Columbia
    Ah , I see what you are saying not , the guts aren't aligning with the decorative plate
    I have very little experience with mortise lock sets , the few I have dealt with in renos of old houses had the multi fuction style lock
  16. Dec 2, 2014 at 3:57 PM
    #36
    Ghost.
    Ghost. [OP] TW 1%er
    Raymond
    Anchorage, AK
    I can tell you it it's not hitting the plate.
  17. Dec 2, 2014 at 4:03 PM
    #37
    Ghost.
    Ghost. [OP] TW 1%er
    Raymond
    Anchorage, AK
    I usually keep a grab bag but I took it out when I did a members headlights. Sitting on the table in my garage now
    Yeah well...i can get groceries like a mofo
  18. Dec 2, 2014 at 4:04 PM
    #38
    Ghost.
    Ghost. [OP] TW 1%er
    Raymond
    Anchorage, AK
    I should have done one when I made my Halloween costume. That was a day long event though. Actually took two days. Got too drunk one night and my stitches were way off lol.
    I will have a new one soon
  19. Dec 2, 2014 at 4:27 PM
    #39
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Kick the door shut as hard as you can exactly 3 times and on the 3rd time it will latch. Works 60% of the time, every time.
  20. Dec 2, 2014 at 4:29 PM
    #40
    OZ-T
    Peter North
    British Columbia
    You figure this out yet ?
