Help, my glove box is jammed.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wvmtb, Mar 9, 2011.
  1. Mar 9, 2011 at 10:13 AM
    wvmtb
    wvmtb [OP] Member
    OK, so I finally decided to change the cabin filter in my truck. I didn’t have any problems getting to it and replacing it. But things went bad when I tried putting the glove box back together.
    Problem #1: Couldn't get the damper to stay on. So I think no big deal. I’ll just wont put it back on for now.
    Problem #2: Once I shut the glove box it won’t open at all.
    I was thinking something got jammed in the latch but I can pry it open far enough that it doesn’t look like that’s the problem. It looks like it might be setting a little higher than normal (because it’s kind of jammed under the upper part of dash. So I’m thinking it might not be snapped into the bottom hinge point correctly. The handle is stuck in the open position and is pretty much useless.
    Guess the reason for my post here is to see if anyone has any suggestions on what I should or can do to get it open. I don’t have access to any dynamite, so that’s not an option. Besides I would like to find a way to open it and put it back so that it’s still usable and looks like it should.
  2. Mar 9, 2011 at 10:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Just try to manipulate it with your hands. Maybe from underneith. The p[lastic is soft, so useing any tools may scare it.
  3. Mar 9, 2011 at 10:19 AM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Have you tried reaching under and forceing it on to the hinges. If that doesn't work I say punch it and show its who's boss. You can't really break anything by giving it a good shove, might just leave some scratches.
  4. Mar 9, 2011 at 10:30 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I would give it a good scolding! Pretend your Sean Connery and smack it like a bitch! Actually, i have had mine jam up on that bottom hinge cause I did not get it all the way on. I wouls give it a little pull from underneith and pull down, see if you can get it on the hinge.
  5. Mar 9, 2011 at 10:31 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  6. Mar 9, 2011 at 10:47 AM
    topgun155
    Zack
    Richmond, TX
    2018 F-150 5.0
    Pussy ^^^^^
    Use a real hammer
  7. Mar 9, 2011 at 11:54 AM
    Jester243
    Dan
    Spokane, WA
  8. Mar 9, 2011 at 12:49 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Well, when you do finally get it open, in regards to your damper, just scew it!
  9. Mar 9, 2011 at 5:01 PM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    Crowbar?
  10. Mar 9, 2011 at 5:05 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    why didnt i think of this!
  11. Mar 11, 2011 at 10:03 AM
    wvmtb
    wvmtb [OP] Member
    Thanks, for all the replies. Good and bad. But I finally got it oppen last night. When I originally put it back on I must not have got it snapped in one of the hinge points which is what jammed it up. Then at some point probably while I was trying to "show it who was boss". I mush have broke the handle.
    Got it released by removing the box off the hinges on the bottom. Then reaching in the box to the 2 screws to remove the handle. It was a bitch but its off now and the only problem I am going to have now is trying to get a new handle. Hate to see what the stealership will want for it.
  12. Jan 12, 2012 at 7:16 PM
    TACODOC1
    TACODOC1 Well-Known Member
    SoCal
    2024 Tacoma Trailhunter - Bronze Oxide
    Handle is about $20 at the dealer, I'm dealing with a similar issue except mine is stuck shut after changing the handle (the original one was getting rattly/noisy), it was working fine but the metal rod that actuates the latch must have popped out... meh
  13. Jan 12, 2012 at 7:21 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Well we all know who is boss now, don't we? :p
  14. Jan 13, 2012 at 5:14 PM
    TACODOC1
    SoCal
    My latch is not working so mine is still stuck shut... any suggestions?
    I tried prying the hinge loose along the bottom but am having a hard time seeing how that will work if the latch is closed. Has anyone actually done this?
  15. Jan 13, 2012 at 8:14 PM
    cmoschip
    cmoschip Well-Known Member
    Robert
    Houston, Texas
    2008 TRD Sport DC 4x4
    X3 - Mine no longer stays on and this is the fix!
