HELP!! My Interior electronics Went HAY WIRE!!
Discussion in 'Technical Chat' started by SuthrnTaco07, Oct 31, 2010.
  1. Oct 31, 2010 at 6:32 PM
    SuthrnTaco07
    SuthrnTaco07 [OP] Well-Known Member
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    I FIXED IT!!!! HOLY CRAP!!!! READ THE RED...
    I have a 2007 Tacoma Access Cab. So yesterday i was in a hurry to get to a wedding when i realized that nothing was working all of a sudden.. My gas guage is floating freely up and down when it feels like it, my speedo don't work, my check engine light came on, my air bag light is on, my turn signals don't work, my reverse beep don't work, my air is stuck on heat and defrost (the last settings i had it on...), and even though my turn signals don't work inside or out my hazzard button does... What is wrong with it!?!?! Possible fuse? Please any help would be great! Thank you! btw... I searched similar words and found nothing of the same story...
    Thank you
    Ok... So i spent $180 on my truck today! Why you ask? Well i realized that my truck needed a goo electrical overhaul and people were telling me that they don't think its a speed sensor or my ECM.. They said i have a loose ground.. MAKE SENSE.. So i check all my grounds and powers for every not factory i have installed... Well after sprucing up my truck and buying a brand new Yellow Top battery i realized it still didn't work. So i checked all my fuses in the engine bay.. NOTHING! So then i checked the ones that made sense under my steering wheel.. NOTHING! So i realized i check 3/4 of the one inside might as well check them all them BAM labeled "IG1 10" blown to shit! I just so happen to have one of those mini fuzes included under the hood as an extra.. Popped it in!! CHA CHING! BLINKERS, CHECK! REVERSE LIGHTS, CHECK!, AIR BAGS, CHECK!! ETC.. It was that simple this whole time! So side note double check before you waste your money at a dealer! The dealer told me it was my ECM by me describing it. Hope this helps someone down the road! Toyota I LOVE YOU!!
  2. Oct 31, 2010 at 6:38 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    what were you doing before this happened.
  3. Oct 31, 2010 at 6:43 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Eh, no. I don't think it's a fuse, it sounds like you're having an ECU problem. All of those things are controlled logically.
  4. Nov 1, 2010 at 11:01 AM
    SuthrnTaco07
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    I wasn't doing anything out of the norm... I went to the movies and then back woke up the next morning and bam... Nothing works... So what do i do? I mean i have a system and stuff but i've had that over 2 years! So i don't know what the deal is!
  5. Nov 1, 2010 at 1:29 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Like I was saying, all of those components don't control anything directly, they send signals back to the computer and then the computer decides what to do, or vise-versa, it's possible your gauge cluster is not communicating, like suppose if you have a frayed or damaged wire or if the cluster itself has gone bad. I'd take it to the dealer and see what they have to say about it.
  6. Nov 1, 2010 at 3:29 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Sounds to me like a bad/loose ground somewhere. Ground loops cause major, and completely random, problems in digital systems.
    Look for every ground you can find, wiggle it and tighten it. Start with the battery ground and the ground wires around the battery, other grounds in the engine compartment and grounds under the dash.
  7. Nov 2, 2010 at 7:19 PM
    SuthrnTaco07
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    Alrighty.. I appreciate all advice and will be checking into it tomorrow during the day and let you know what the deal is... I hope it is not the ecu! AHHHHH!!! Anyways... I'll let ya'll know..
  8. Nov 12, 2010 at 1:42 PM
    ProtoJ
    ProtoJ Well-Known Member
    Colorado
    07 TRD Sport Double Cab, Superwhite
    Removed 2nd air fliter, AFE Pro Dry filter, Scangauge II, shorty antenna, ARE CX Topper, URD Short Throw w/ TRD Shift Knob, Toyota Chrome Exhaust tip, FJ TRD Center Caps, Westin Prerunner bar w/ Hella 500 Lights, Hardwired Garmin
    I had that happen on a Ford Ranger once. I ended up replacing the battery and that fixed it. The radio even turned on/off by itself.
  9. Nov 12, 2010 at 3:25 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    A blown 7.5A ECU-B fuse (engine bay) might explain most, if not all, those symptoms.
  10. Nov 12, 2010 at 3:28 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
  11. Nov 12, 2010 at 3:32 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    I don't know a fuse is either in tact or is blown...no in between. I mean if it was blown wouldn't it just not work? Really sounds like it could be a grounding issue or the ECM is malfunctioning. Curious to find out what it is. :popcorn:
  12. Nov 12, 2010 at 3:34 PM
    SuthrnTaco07
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    ok.. So an up date.. I might try doin gthe cheaper fixes first.. AKA(Battery, Fuse... ETC) but i ran a code the other day and it cam back with (I think) PB 5300 (or something like that) aka what it is know as Speedometer sensor and if it is wired like i think when one goes bad all others start to flag and make it look worse.. So i'll do the cheap ones first then onto the $140 sensor!!
  13. Nov 12, 2010 at 3:35 PM
    jivewalker
    jivewalker me gusta pechos firmes
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS
    you weren't near devils peak were you?
  14. Nov 12, 2010 at 3:55 PM
    SuthrnTaco07
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    LOL!! Nope.. Just normal everyday driving..
  15. Nov 20, 2010 at 7:18 AM
    chilidogrc
    chilidogrc Play stupid games, win stupid prizes
    Rodrigo
    San Diego
    2016 4Runner
    Any update on this?
  16. Dec 6, 2010 at 6:29 PM
    markustyson
    markustyson Member
    Victoria, BC
    2008 Tacoma 4x2
    I've got a similar problem..but with the tailights and climate control/radio lights. I indiacate left and everything starts flashing. All interior lights are off, but then I hit the brake and they're on again.
    Even stranger..sometimes the problem fixes itself, other times it goes back to bad.
    Checked my grounds and fuses and everything is good. Going to the shop Wed so I WILL provide an update.
  17. Dec 14, 2010 at 11:17 PM
    SuthrnTaco07
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    UP UP AND AWAY!! I FIXED IT!! READ FIRST POST!! EDIT!
  18. Dec 14, 2010 at 11:19 PM
    SuthrnTaco07
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    Thinking about it.. It could very well be a fuse that is barily making contact sometimes and that is why it is flickering and fixing it self on and off!
  19. Dec 15, 2010 at 9:25 AM
    markustyson
    markustyson Member
    Victoria, BC
    2008 Tacoma 4x2
    Mine was a faulty trailer wiring harness. Water got in and arc the pins.
    Time for a new one....
