help my squeaky leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clermontmx118, Nov 20, 2009.
  1. Nov 20, 2009 at 9:13 AM
    clermontmx118
    clermontmx118 [OP] New Member
    gabe
    florida
    2005 tacoma
  2. Nov 20, 2009 at 10:13 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    try using the search button, a few topics on this. BUT if you pressure wash them and apply grease to them it will stop. One thread i read states exactly which grease to use.
  3. Nov 20, 2009 at 10:16 AM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    pressure washer and a good all weather grease and you will be good to go
  4. Nov 20, 2009 at 10:28 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Buy a can of Silicone lubricant with teflon. Wedge a flat head screwdriver between the leaves near the end where the pads are (to separate the leaves a little) and spray the lubricant between the leaves where the contact pads are.
    That should stop the squeaking for about 6 months...
  5. Nov 20, 2009 at 11:06 AM
    boks
    boks From Michigan!!
    Michigan
    2020 4WD TRD-Offroad Double Cab
    Rhino RTS ditch mount roof rack tracks Truxedo Lo Pro tonneau cover Yakima tracks on Bed rails LED Interior Light upgrade Former Vehicle: 2007 4WD TRD-Offroad Double Cab
    Take it in to the dealer, there's a TSB on the squeaky rear leaf springs. I brought mine in last week and they fixed it. I'll try and find the TSB number for it, I know it's on the info they gave me. There are some type of pads between the leafs that need to be replaced. As long as you're still under 3 years you should be good.
  6. Nov 20, 2009 at 11:19 AM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    Got my creak/squeak fixed yesterday......About two months ago I had a set of long AAL's installed at a local Springshop.Almost immediately they started creaking like a MoFo and it was driving me nuts.I had them lubed during my MVI and it went away for a couple of weeks but came back worse than ever.Yesterday I went back to the shop and they installed plastic isolators at no charge and she's back in stealth mode.:D
  7. Nov 20, 2009 at 11:22 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    his 05 is far past tsb warranty
  8. Nov 20, 2009 at 11:36 AM
    boks
    Michigan
    After I posted I went back to look if the truck year was listed. Yeah, 05 isn't covered. Do you know if you have to pay for a TSB after warranty is up? Is it worth going to the dealer or getting the plastic insulators like squad314 did?
  9. Nov 20, 2009 at 12:07 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    squirt some chain lube for motorcycles in there,works good and sheds dirt.
  10. Nov 20, 2009 at 12:10 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    the dealer (I already tried) is going to charge you $200 for some stupid silicone pads. If you can, takem apart and clean real well and relube with white lithium grease.
  11. Nov 20, 2009 at 1:42 PM
    clermontmx118
    gabe
    florida
    2005 tacoma
    thanks guys, i'll try it all and tell you waht works.
  12. Nov 20, 2009 at 1:54 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Here is a posting I wrote up for someone else who had the same issue. It could be worth a try.
    Link: http://www.tacomaworld.com/forum/2nd-gen-tacomas/57301-annoyin-hell-2.html#post1078152
  13. Nov 20, 2009 at 3:21 PM
    squad314
    Marc
    I would be willing to take some pics of what my shop did for me if anyone was interested........It doesn't look like rocket science,and if they didn't charge me for it,you can be assured it is cheap.:D
  14. May 11, 2014 at 7:04 PM
    JJ48Nascar
    JJ48Nascar Member
    Josh
    08 Tacoma Prerunner V6 4.0L
    17 inch rims with Nitto Grappler tires. No lift kit
    I would love to see some pics. I am having the same problem and would like an easy cheap fix to get rid of the annoying squeak.
    Thanks
  15. May 11, 2014 at 7:10 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Old thread is old
    Check out the squeaky leaf fix thread
  16. May 11, 2014 at 7:10 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    If u unbolt ur shock and put a bottle jack between the leaves and frame, u can get really good separation of the leaves and get grease all the way to the ubolts practically.
  17. May 11, 2014 at 7:12 PM
    OZ-T
    Peter North
    British Columbia
    Or just get the TSB isolators from Toyota
  18. May 11, 2014 at 7:19 PM
    yota243
    E.J.
    north Alabama
    What year does that go back to?
  19. May 11, 2014 at 7:27 PM
    OZ-T
    Peter North
    British Columbia
    They are larger isolator pads you can buy and put on your stock leafs , there is a link to them near the end of the DIY squeaky leaf fix thread
  20. May 14, 2014 at 5:08 AM
    JJ48Nascar
    JJ48Nascar Member
    Josh
    Thanks for the info!
