help!! my temp gauge and fuel gauge dont work
Discussion in '1st Gen. Tacomas (1995-2004)' started by tldpro317, Dec 10, 2009.
  1. Dec 10, 2009 at 6:02 PM
    tldpro317
    tldpro317 [OP] New Member
    Hey, I have a 95 4x4 ext cab sr5 and my fuel gauge and temp gauge dont work, every once in a while the temp gauge will bump up but then it just drops back to zero, the fuel gauge doesnt ever attempt to move, I know it could be the sending unit but wondering if the two are somehow connected. also my cruise wont work, It lights up on the dash but wont take over the speed. any opinions would be great.
  2. Dec 13, 2009 at 6:39 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    Check the fuses...mabye:confused:
  3. Dec 14, 2009 at 5:00 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Is it an aftermarket cruise control? If so - what make / model?
  4. Dec 14, 2009 at 5:09 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    One thing the fuel and temp gauges have in common is the ground point. It's located behind the left kick panel. The primary ground wire you're looking for is brown.
    Are you having 'issues' with your speedometer and / or tach? Both these items are on the same circuit, so I'm having a hard time figuring out how you'd be getting 'fail' on the temp and fuel gauges alone.
    If it's a Toyota cruise control, your cruise control ECU ties into the cluster jointly (co-wired via connector) with the 4WD ECU and the main / engine ECU. I can't figure out how a bad cruise ECU connection could cause the problems you listed without affecting the engine management and the 4WD functions.
