Help Needed, 2009 Access Cab Losing Power and Brake Lights Coming On
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RedneckPunk, Jan 15, 2022.
  1. Jan 15, 2022 at 8:36 AM
    RedneckPunk
    RedneckPunk [OP] New Member
    Chad
    2009 Toyota Tacoma Access Cab
    My 2009 Access Cab has started losing power for a couple of seconds at a time then smooths out. The only light on the dashboard is the "tire pressure" light. When I got home, I noticed the brake lights would come on for a few seconds and then go out randomly while sitting in the driveway, not running. Has anyone else had this problem or have any advice?
  2. Jan 15, 2022 at 8:39 AM
    Spankomatik
    Spankomatik Well-Known Member
    JD
    IL
    2021 celestial silver metallic AC SR SX 4x4 2.4L
    Fog lights, switch panel, cab storage platform
    Something like this happened to one of my friends. Turns out squirrels had been chewing cables up in the engine compartment.
  3. Jan 15, 2022 at 8:52 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Could be coils
  4. Jan 15, 2022 at 11:12 AM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    Sounds like a vacuum leak to me
  5. Jan 15, 2022 at 5:10 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Are your brake lights low on fluid?
  6. Jan 15, 2022 at 5:51 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I would address the brake lights first (likely a bad or mis-adjusted switch).
    I'm not sure what year it was added but newer vehicles have a safety feature called brake override, if the ECM detects a brake signal it will reduce engine power to allow the vehicle to be slowed down in the event of a stuck throttle.
    JKD and Jimmyh like this.
  7. Jan 17, 2022 at 8:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This ^^^^^
