Help Needed - CE Light with P0430/0420 Codes and UltraGauge Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4myTaco, Mar 4, 2016.
  1. Mar 4, 2016 at 1:12 PM
    4myTaco
    4myTaco [OP] SmaSh it Up
    Lucas
    Plainfield, IL
    06 DCLB Sport
    OME 3" lift up Front, LR UCA's, All-Pro Expo leafs in back, 17" XD Addicts with 285/70/17s, OEM Roof Rack, Westin Light Bar, Relentless Tailgate plate, Weathertech's, Blue Sea Fuse Box, Iggy's Switch Holder, Pioneer avh-3300bt Radio, LED Interior/License Plate Lights
    Hey guys, long story short, i JUST got my truck back from having the frame replaced, and the CE light came on at the dealer, they told me about it and cleared the code. About 30 miles later, it was back on, and has been on for the last two days. My truck sat in their lot from the middle of November until now, but prior to taking it in I have never had any issues or had a CE light on.
    I find it almost too much of a coincidence that I didn't have any issues until my truck was torn apart, my question is, is there anything I could do with a scan tool like an UltraGauge that could tell me if it was the actually the cats, or just a sensor? I don't really want to spend the $2k + on new cats if that isn't the issue.
    Edit: I should add, there are not any signs of a rough idle, or hesitation that might indicate a clogged cat.
  2. Mar 4, 2016 at 3:27 PM
    Aguaski
    Aguaski Well-Known Member
    Clint
    2014 DCSB OR Prerunner
    Any strange rattling noises when you rev the engine? Sometimes when the cat is bad you can hear a rattling sound. Since your getting both P0420 and P0430 makes me think it is a O2 sensor issue and not a cat issue. If you had no CE codes prior to the dealership work then I would take it back and have them fix it.
  3. Mar 4, 2016 at 3:31 PM
    4myTaco
    Lucas
    Plainfield, IL
    06 DCLB Sport
    Definitely no rattling that I can hear, i had a cat go bad in my s-10 when I was younger so that was the first thing I checked. I ran some fuel system cleaner through thinking maybe it was just old gas even though I put stabil in when I dropped it off. I will probably go back to the dealer on Monday and see what they will do.
