Help Needed: Cold Shift Trouble & Steering Rack Vibration on My ‘99 PreRunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ayush Ramkhelawan, Jun 23, 2025.
  1. Jun 23, 2025 at 6:32 PM
    Ayush Ramkhelawan
    Ayush Ramkhelawan [OP] Member
    Ayush
    Suriname
    1999 Tacoma prerunner v6
    Hey everyone, I wanted to share a couple of issues I’ve been dealing with on my 1999 Tacoma PreRunner 3.4 V6 and see if anyone here has experienced something similar or has any advice.
    Problem #1:
    When starting the truck cold, it won’t shift past 2nd gear. There’s no unusual noise or hard shifting — it just stays in 2nd until the truck warms up a bit. The transmission fluid level is fine. I did notice a small leak around the edges of the transmission pan, but I keep an eye on the fluid and top it off when needed. Still, this issue happens every cold start.
    Problem #2:
    I’m also getting a vibrating or buzzing sound when I turn the steering wheel. I tracked the vibration to one of the lines attached to the steering rack, but I’m not sure what’s causing it or the best way to fix it.
    Any tips, advice, or shared experiences would be greatly appreciated. Thanks a lot in advance!
  2. Jun 24, 2025 at 4:09 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    YO
    Ayush
    Fill out your profile completely!
    (Tranny)
    your #2
    Sounds like p/s system starving for fluid that results in tht vibration of steering wheel
    Check condition/color of fluid
    then
    Search “cleaning P/S reservoir screen”
    there is a screen incorporated into the reservoir. This screen gets clogged with debris….not letting appropriate amount of ATF fluid to get to pump/steering rack
    Easy fix!
    Drain reservoir
    Take off reservoir and clean screen with brake cleaner
    Use a flashlight on one end of reservoir to monitor your progress
    2 tips
    -buy MORE than one can of BClean
    -replace the reservoir O-ring to prevent future leaks
    this was my 1st project when I got my Taco
    The fluid was jet black
    Screen 70% clogged
    No issues since!
    Ayush Ramkhelawan[OP] likes this.
  3. Jun 24, 2025 at 7:54 PM
    Ayush Ramkhelawan
    Ayush
    Suriname
    Thanks a lot for the detailed advice! I’ll definitely check all of this out tomorrow. I had a feeling it might be something in the power steering system starving for fluid, but didn’t know about that screen in the reservoir.
    Appreciate the tips about cleaning it and replacing the O-ring too — I’ll grab a couple cans of brake cleaner before I start.
    I’ll update here once it’s done!
  4. Jun 24, 2025 at 8:03 PM
    Ayush Ramkhelawan
    Ayush
    Suriname
    Also, just a quick update on the transmission issue — the gearbox fluid is completely full. Last night I was reading through a few posts here on the forum, and someone mentioned letting the truck idle for 4 to 5 minutes before driving. So this morning, I let it run for about 5 minutes before heading out, and the transmission shifted perfectly fine. Same thing this afternoon after work — I waited 5 minutes, and it shifted with no problem at all.
    It’s kind of strange though, because I’ve never experienced this before. I’m starting to wonder if maybe the thickness of the fluid is playing a role when it’s cold, or if it could be something like the transmission filter.
    I actually replaced both the fluid and the filter last December, so I might have to check them again just to be sure.
    Appreciate all the help here — I’ll post an update once I’ve checked
    ControlCar likes this.
