Help needed diagnosing Tranny Prob
Discussion in '1st Gen. Tacomas (1995-2004)' started by WesleyA, Jan 4, 2012.
  1. Jan 4, 2012 at 10:23 PM
    WesleyA
    WesleyA [OP] New Member
    01 PreRunner
    Automatic 4cyc 2001 Tacoma 2WD.
    Last night cruising down the freeway RPMs jumped as if tranny slipped into neutral, no power, no speed, like the transmission died. Tried shifting out of Drive into 2nd and gears didn't grabb until I coasted below 50mph. I limped it through some back roads for a few miles before 2nd also disengaged. Sat on the side of the road thinking my transmission randomly (without warning) died. Turned off my truck, called AAA. Few minutes later tried to re-start my truck and the Starter just spun as if it wasn't even engaging the flywheel.
    Gonna tear into it in a few days, but does this sound like a dead transmission?? Torque Converter or Flywheel?
    The only thing that made me think twice was the fact my truck wouldn't start afterwards.
    Any helps appreciated guys, I love my truck to pieces and this is the first problem I've ever had with it.
  2. Jan 4, 2012 at 11:38 PM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Arizona
    03 Prerunner SR5 2wd
    That's pretty odd. Have you had anything worked on recently?
  3. Jan 4, 2012 at 11:49 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I can't comment on the truck not starting, but dude, you better pray its not your trans. Some of what you mentioned is what mine was doing before it ,without much warning grenaded, & I mean it fuckin' exploded inside, got towed home & 2 days later I dropped the pan only to find about a pound of metal shavings/ broken gear teeth on the bottom....
    Uhhh, try about $2k & up to $3k (for an absolute rebuilt including all the servos)
    & yeah my truck has been out of commission since Halloween...
    good luck to you & hoping yours isn't like mine....:(
  4. Jan 4, 2012 at 11:57 PM
    WesleyA
    01 PreRunner
    the truck has had no mods or heavy maintenance ever.. 100% stock with regular maintenance and upkeep. The fact this did happen is quite a shock and mystery to me.
  5. Jan 5, 2012 at 12:09 AM
    MacGyvR
    Tom
    Arizona
    I would check the fluids to make sure they're normal and not full of burnt crap or discolored. Is it leaking from anywhere?
  6. Jan 5, 2012 at 12:55 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
  7. Jan 5, 2012 at 11:14 AM
    Milkhotdog
    Milkhotdog Member
    B.C. Canada
    project!
    5100s+OME 881s, Cistom HD leafs+5125s, BFG 33x12.5 15s, swapped in elocked+trussed axle, 4.56 gears, Bushwacker cut out fender flares.etc.
    Sounds like maybe your timing belt snapped?? This happened to my brothers 94 Toyota. Very similar symptoms. This would not be a big deal.
  8. Jan 5, 2012 at 1:47 PM
    WesleyA
    01 PreRunner
    Called a buddy who runs a shop, he suggested my Flex Plate broke that presses on the flywheel and keeps it in position.. which is why my truck wouldnt start as the starter couldnt engage the flywheel properly.
    Flex Plates are only $120 so I'm praying
  9. Jan 9, 2012 at 9:47 AM
    MacGyvR
    Tom
    Arizona
    any updates?
  10. Jan 9, 2012 at 9:53 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I was thinking flex plate also, leading to torque converter disconnect!
