Help Needed for Front End Growling/Vibe Fix
Discussion in 'Northern California' started by tacomtn, Jan 3, 2012.
  1. Jan 3, 2012 at 5:40 PM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    Hey, guys.
    I've developed the dreaded bearing, diff, or whatever the heck the cause is for a growling noise/vibe front end problem. I've done some research and it seems it's likely my bearings are shot, or its the diff drop, or not the diff drop, or IDK. The CV boots are intact, my truck is a 2011 with only 9400 miles, 3" OME lift.
    I was hoping to have help installing my new sliders and skid plates, but this problem is priority now.
    Anyone available this weekend, maybe Sunday?
  2. Jan 3, 2012 at 6:13 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Dude, youre under warranty... just take it to the dealer. if youre trying to determine if it is the needle bearing all you need to do is put it into 4wd and if it goes away it is the needle bearing.
  3. Jan 3, 2012 at 7:52 PM
    tacomtn
    Yeah, I was going to try the 4WD engage test tomorrow. I was thinking of the dealer but since my truck is lifted, I'm afraid they won't help. I guess it doesnt hurt to ask.
    Funny thing too, it only seems to make the noise when warmed up, not cold. I've been reading that some have this same only-when-warm issue too.
  4. Jan 4, 2012 at 3:23 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Where do you live again.... I don't mind.... but I ain't driving anywhere :p
  5. Jan 4, 2012 at 8:30 PM
    tacomtn
    I'm in San Jose.
    I tried the 4WD engagement, noise continues, no change. CV joints, diff, wheel bearings? Help.
  6. Jan 4, 2012 at 9:05 PM
    brian
    Elizabeth City, NC
    If you feel it and hear it... its probably the wheel bearings. Just take it in man.
    Grab the tire and shake it side to side, do you feel any play on the hub? I'm slowly starting to thing on t hese trucks its not a solid indicator because I think mine are going but the hub still feels solid.
  7. Jan 9, 2012 at 10:01 PM
    DATZ WEAKSAUCE
    DATZ WEAKSAUCE Well-Known Member
    San Jose, CA
    17 DCLB TRD OFF ROAD LT PROJECT
    wheel bearings dont need to have play to be bad they can be jacked up internally wont cause any vibration though will just sound like an airplane or loud tire noise
    and if you take your car in i would highly recommend taking the lift off depends on how they are they can be dicks and just void your warranty if they wanted too and say the damaged part is caused by the lift etc etc i work at a dealership but not at toyota =X
  8. Jan 12, 2012 at 9:15 PM
    DATZ WEAKSAUCE
    San Jose, CA
    find out what it is yet?
