Help Needed. My 2020 engine misses
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Justinhisle, Dec 19, 2021.
  1. Dec 19, 2021 at 12:34 PM
    Justinhisle
    Justinhisle [OP] Well-Known Member
    Justin
    Kentucky
    2020 Tacoma TRD off-road
    I have a 2020 Tacoma OR AT 4x4 with 31,000 miles on it. So several months ago I began to notice a slight miss with the truck, mainly when under a load. The miss is very subtle and doesn’t do it all the time. It is mainly at around 1200 rpms or 1900 rpms. The best way to describe it is: it’s like a stick shift; when you have a standard in too high of a gear, it can sputter until you downshift. It’s similar to that.
    so I took it to the dealer and they couldn’t find anything wrong with it and sent me on my way.
    Then I took it to another dealership and they said it was the transmission, so last week they put an entirely new transmission in it. And unfortunately, it still misses. I have never had any check engine lights or any fault lights show up. I do think it is an issue with the engine though, not the transmission
    Anyone have any idea what may cause this? Im at the point, not sure what I should do. Any help is greatly appreciated.
  2. Dec 19, 2021 at 12:42 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Damn, a new free transmission when you didn't even need it? That's a win.
    Fuel pump issue? CPS? Has your truck had any TSBs applied?
    Mark77, Junkhead and Justinhisle[OP] like this.
  3. Dec 19, 2021 at 12:51 PM
    Justinhisle
    Justin
    Kentucky
    I know right. But no, not that I’m aware of. That was my thought too, I keep thinking it’s some sort of fuel issue. It’s just so odd, because it doesn’t do it all the time. I can usually make it miss tho. Just by getting the rpms lower and holding steady so it doesnt downshift. As soon as the truck downshifts the missing stops. But like if I’m on the interstate cruising, I notice it there way more than in town.
  4. Dec 19, 2021 at 12:54 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Quite a few threads on this. Seems pretty common, especially around 40-50mph at 1200rpm. Some trucks do it, some don't. Mine does it too.
  5. Dec 19, 2021 at 12:55 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think the plugs need changing at 30k. I’d start there. Good luck!
    Justinhisle[OP] likes this.
  6. Dec 19, 2021 at 1:06 PM
    Justinhisle
    Justin
    Kentucky
    Have you had any dealer/service centers look at yours? I’m trying to look back at old threads, to see what others have said. I dont want to just “accept”, that it is a common issue and let it go. I paid a lot of money to buy a brand new truck and expect it to work properly. Especially when it only had 31,000 miles on it. Any vehicle with a miss, is not normal and is certainly not working properly. If I went to try and sell it and someone tests drives it, and it misses, they would most likely lose their interest of purchasing it. But it’s extremely difficult to get a service center to correctly diagnose jt, since it doesn’t do it all the time.
  7. Dec 19, 2021 at 1:06 PM
    Justinhisle
    Justin
    Kentucky
    Definitely a possibility
  8. Dec 19, 2021 at 1:15 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Try a tank of higher octane fuel and report back.
    Junkhead, Justinhisle[OP] and rnish like this.
  9. Dec 19, 2021 at 1:17 PM
    Lt. Dangle
    Ohio
    3rd gen is 60k. V6 is anyways.
    kgilly, Taco361, Junkhead and 2 others like this.
  10. Dec 19, 2021 at 1:36 PM
    Justinhisle
    Justin
    Kentucky
    I’m glad you said that. I had thought about doing that a while back but forgot to try it
    Lt. Dangle[QUOTED] and Junkhead like this.
  11. Dec 19, 2021 at 1:46 PM
    eurowner
    eurowner Duke Sky
    Scoty
    If you can, get it on video.
    Justinhisle[OP] and Mark77 like this.
  12. Dec 19, 2021 at 1:54 PM
    scottc
    scottc Well-Known Member
    Raleigh NC
    2019 TRD Sport 4X4
    KDMAX- Pro Tune TRD Exhaust
    I guess it's more common than I realized. I get the same miss when cruising under lite throttle, usually in 6th gear at low rpms 1350-1600. I also sense it on the interstate but not quite as bad. I thought maybe the KDMAX-Pro tune would fix it but it's still there. More annoying than anything but doesn't seem like its right. 28,400 miles on mine. I can't say but not sure if it did this before the last TSB for the trans shifting issue or not.
  13. Dec 19, 2021 at 1:56 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    X2.
  14. Dec 19, 2021 at 2:03 PM
    scottc
    Raleigh NC
    2019 TRD Sport 4X4
    I wish I could, but on mine it's more of a feeling than something you could document on a video. I'll try the higher octane this week and see if that helps.
    Lt. Dangle and Justinhisle[OP] like this.
  15. Dec 19, 2021 at 2:07 PM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    My 2019 4cyl would have a ever so slight stutter when accelerating, not all the time, just occasionally. Got a new fuel pump with the recall and it hasn't done it since.
  16. Dec 19, 2021 at 2:29 PM
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    The plugs don't "need" to be changed at 30,000 - I still have the originals in at 90,000 and they are all good on color, impedance, and gap. The book says to change them strictly for CARB / emissions warranty - not performance.
  17. Dec 19, 2021 at 2:37 PM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Or a loose spark plug. A lot of guys found a loose one when they went to change them.
  18. Dec 19, 2021 at 2:52 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Is it making a knocking noise like a diesel?
  19. Dec 19, 2021 at 3:09 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Are you running the AC?
  20. Dec 19, 2021 at 3:36 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    I don't think it's an octane issue but do you have a brand of fuel you use predominantly? Could play into it. I would consider a fuel issue as the system kicks between Direct injection and Port injection...which these motor do. It can sometimes cause a momentary seat of the pants sensation where it doesn't at any other point in the spectrum. I even have outboards that experience this issue.
    Spend $60 and try the ATS Fuel Treatment. It's serious stuff and works way better than the shit like SeaFoam and others....that just DON'T. https://www.atscarbonclean.com/
    You don't want to use the engine oil half of the combo, I doubt you'd need that for a long, long time but you have to get the combo.
    Re: The transmission. Did you get a completely new factory tranny/torque converter, a factory reman, or a rebuild?
