Help needed rear driver side door stuck shut
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toytruck864, Apr 13, 2024.
  1. Apr 13, 2024 at 10:52 AM
    Toytruck864
    Toytruck864 [OP] New Member
    2013 Tacoma XSP-X Prerunner 4 Dr
    Hi group,
    I really need some help here. I have a 2013 Prerunner 4 door. When I changed the door lock motor I replaced with the wrong part. A round shaft motor and I needed the D shaft motor. Now my door is stuck shut. Can’t open from the outside or the inside. I took the inside panel off and can’t get this resolved. Anyone know what I need to do?
  2. Apr 13, 2024 at 11:34 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Maybe the post below will help.
    https://www.tacomaworld.com/threads/stuck-door-latch-actuator-fix-writeup.531728/
    Just a caution/tip for anyone that runs across this, make sure after doing any work on a vehicle door that requires messing with any of the latch/lock assemblies or linkages use a screwdriver to latch the latch and make sure everything works and it unlatches before ever closing the door. It's a royal pain to deal with it once the door is closed.
    Jimmyh likes this.
  3. Apr 13, 2024 at 12:29 PM
    Toytruck864
    Thank you!
    You are a life saver. Hope you have a great weekend.
    Jimmyh likes this.
