Help needed with 3'' lift
Discussion in 'Suspension' started by anders99, Oct 10, 2013.
  1. Oct 10, 2013 at 11:20 AM
    anders99
    anders99 [OP] The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    As my truck sits right now it looks like I have a toytech leveling kit with the 3'' spacer up front but I have no idea what was done to the rear. When I look at the rear I have 3 leafs with an overload leaf. What needs to be done to get at least 3'' of lift with coilovers up front and keep the truck level? I was looking at the Toytech ultimate kit but if all I have to do is get new coilovers that is what I will do.
    Here is the front
    Here is the rear
  2. Oct 10, 2013 at 11:37 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    So does the truck sit level as it is now?
  3. Oct 10, 2013 at 11:38 AM
    anders99
    Matthew
    Penscola, FL
    Correct. It sits level right now
  4. Oct 10, 2013 at 11:41 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    take the spacers off buy new shocks and coils and add a leaf out back call toytec or wheelers and they will talk you through everything and you'll get answers alot quicker than you will on here. i bought mine from toytec and they were extremely helpful
  5. Oct 10, 2013 at 11:41 AM
    CCPTacoma
    CCPTacoma Well-Known Member
    Noah
    Boise, ID.
    09 Trd Sport DCLB
    Your truck probably has a rear block making it level with the 3in spacer in the front. It will just be a 2-3in block of steel in between the leafs and the axle just look again you'll most likely see it. If you go with the Toytec ULK (much recommended) then you can just get an AAL which is like 100$ or complete new leaf packs which will run around 400$(Dakars). I recommend going with an all around lift to get a complete, level look on your truck.
  6. Oct 10, 2013 at 11:46 AM
    anders99
    Matthew
    Penscola, FL
    Checked for a block but there isnt a block. I am saying it is 3'' because by some freak chance I ran into the previous owner in my town and had a discussion about it.
  7. Oct 10, 2013 at 11:55 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    show us a pic of what you have and we'll tell you what it is
  8. Oct 10, 2013 at 12:36 PM
    anders99
    Matthew
    Penscola, FL
    Here is the front.
  9. Oct 10, 2013 at 2:12 PM
    anders99
    Matthew
    Penscola, FL
    Here is the rear
  10. Oct 10, 2013 at 4:15 PM
    CCPTacoma
    Noah
    Boise, ID.
    09 Trd Sport DCLB
    Alright you have no block in the back so it looks like the previous owner just put a leveling kit on the truck to level the front with the back/ (since the back sits higher stock) I would personally recommend either OME or Toytec ULK
    I currently have the toytec on my 09 Tacoma and it rides great, my brother had an OME setup on his FJ Cruiser which has the same front setup as the Tacoma and he liked it a lot.
    Edit: looking closer at your pics it looks like you have an AAL (unless your truck had 3 springs stock) but it looks like mine currently with an AAL.
  11. Oct 10, 2013 at 6:40 PM
    anders99
    Matthew
    Penscola, FL
    Thanks for the reply. I dont know what it came with stock and dont remember what the previous owner said about the rear. I ran into him a walmart parking lot, he ran across the parking lot saying "Hey thats my truck". Turns out he had traded it in 3 days earlier for a camry.
  12. Oct 11, 2013 at 7:49 AM
    CCPTacoma
    Noah
    Boise, ID.
    09 Trd Sport DCLB
    Yea it looks like an AAL to me, its shorter, you can see more arch in it and your truck is level with a 3in spacer in the front. That setup will do you fine for a while but my front suspension started to make a popping noise when I had my steering wheel all the way to one side so I convinced my parents to help me out with a new Toytec lift and that fixed it up real nice.
  13. Oct 11, 2013 at 8:53 AM
    anders99
    Matthew
    Penscola, FL
    mine is starting to make that noise and I just want to get rid of the spacers. It feels like I have no travel what so ever up front
  14. Oct 11, 2013 at 6:10 PM
    CCPTacoma
    Noah
    Boise, ID.
    09 Trd Sport DCLB
    I would recommend getting bilstein 5100 with eibach springs that fixed the popping noises and made the ride near 100000000000x better than the spacers.
  15. Oct 11, 2013 at 6:42 PM
    anders99
    Matthew
    Penscola, FL
    I was going to go with the Toytech Ultimate kit.
  16. Oct 11, 2013 at 9:08 PM
    locovet
    locovet Member
    oregon
    trd off-road
    I just put mine on last weekend. I think it rides better than it did from the factory. Liking it so far!
  17. Oct 11, 2013 at 9:11 PM
    anders99
    Matthew
    Penscola, FL
    Sweet thanks. I got mine with the spacers already on but they make it feel like there is absolutely no travel in the front end.
  18. Oct 12, 2013 at 5:54 PM
    CCPTacoma
    Noah
    Boise, ID.
    09 Trd Sport DCLB
    The Toytec Ultimate kit has Bilstein 5100 shocks and a special adjustable coil that you can adjust with a spanner wrench while its mounted on your car. Its the upgraded version of what I have w/ just the regular eibach springs but essentially the same thing.
  19. Oct 12, 2013 at 6:18 PM
    anders99
    Matthew
    Penscola, FL
    Ok thanks for the info. Thats some of the best stuff I have heard since I became a member here
  20. Oct 12, 2013 at 6:22 PM
    CCPTacoma
    Noah
    Boise, ID.
    09 Trd Sport DCLB
    Yea I would recommend that or an OME (Old Man Emu) setup
