Help new guy diagnose Tacoma
Discussion in 'Technical Chat' started by ShishkaBOMB, Aug 26, 2010.
  1. Aug 26, 2010 at 9:43 AM
    ShishkaBOMB
    ShishkaBOMB [OP] Well-Known Member
    Hi all, new guy here just bought a Tacoma.
    1stgen 3.4L Supercharged
    I pulled the plugs (Denso IK22 Iridium) to see if they need to be replaced. From the looks of it i think they might be a sign of a deeper problem.
    The side electrode looks like part of it melted off. And there is clearly oil on the plugs.
    Truck is only running the supercharger with no fuel mods. I also get slight knocking at idle occasionally and on hills.
    What should i do?
  2. Aug 26, 2010 at 9:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    Use a higher octane fuel. 91 or better.
  3. Aug 26, 2010 at 9:56 AM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    Detonation Damage: This plug condition indicates that your engine timing is off and you probably need a tune-up. Another possibility is that the gasoline you're using does not have a high enough octane rating.
  4. Aug 26, 2010 at 10:09 AM
    ShishkaBOMB
    I'm running 91 octane and i think the timing is about right because the truck passed smog.
  5. Aug 26, 2010 at 10:17 AM
    98tacoma27
    Ben
    Not Beech Creek
    Then you may need a "colder" spark plug, or is it a "hotter" plug. I forget.
  6. Aug 26, 2010 at 10:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    I honestly think you are running the wrong plug. You would be better off going back to the dual electrode stock plug. The 3.4 is very picky when it comes to plugs.
  7. Aug 26, 2010 at 10:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I agree with 98tacoma. Looks like you need a colder plug. Also, Your running WAY lean. You need to get more fuel in your CC's...
  8. Aug 26, 2010 at 10:25 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Your timing can still be off and pass smog. Running too advanced will make it run hot, detonate, and melt plugs. Using the wrong heat rated plugs will make the ground melt too.
    Check your timing and make sure, or just keep running it with the knock and see what happens;)
  9. Aug 26, 2010 at 12:17 PM
    ShishkaBOMB
    Thanks for the replies. What kind of plug should i run?
    Based on this chart:
    http://www.ngk.com/glossaryImages/93.jpg
    I believe oem is Denso 16 (dual electrode) 90919-01192 (K16TR11).
    I am running Denso 22, 2 ranges cooler.
  10. Aug 26, 2010 at 12:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    BKR7E-11 gapped at .040
  11. Aug 26, 2010 at 12:30 PM
    ShishkaBOMB
    Thanks. The BKR7E-11 appear to be the same as the Denso IK22. 2 ranges cooler than oem and single electrode. Aren't much different?
  12. Aug 26, 2010 at 12:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No...they seem about the same, but alot of people have good results running them.
  13. Aug 26, 2010 at 12:34 PM
    ShishkaBOMB
    Thanks, those are not too expensive so i will try them out and see what happens. :D
  14. Aug 26, 2010 at 12:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What fuel mods are you running?
  15. Aug 26, 2010 at 2:11 PM
    ShishkaBOMB
    No fuel mods, just supercharger. But after some research, it looks like there is a lot more work involved in getting this thing running right.
