Help! New Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HogBalls, Dec 27, 2012.
  1. Dec 27, 2012 at 3:29 PM
    HogBalls
    HogBalls [OP] Hog
    Shane
    Idyllwild California
    2010 Toyota Tacoma SR5
    Plasti Dipped all emblems, Painted Valance, Grill & Emblem Painted rear Bumper Painted Stock Rims 3" Spacer lift from Velocity Offroad 3" Differential Drop
    Hi All, I've been going through these threads with no luck finding a straight answer. So here is my question.
    I have a 2010 Tacoma, I'm looking to buy new tires. I will be putting a 3" lift on it before I get new tires but I'm keeping the stock 16" rims for now. So I want to find out what the biggest size I can go without any rubbing issues?
    Your input would be greatly appreciated.
  2. Dec 27, 2012 at 3:49 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
  3. Dec 27, 2012 at 3:59 PM
    HogBalls
    HogBalls [OP] Hog
    Shane
    Thanks for the Link, Yeah I've heard about the backspacing issue. Looks like 265/75/16 are about as big as you can go without buying new rims with the proper backspacing.
  4. Jan 21, 2013 at 4:06 AM
    SuperLoad
    SuperLoad Member
    StL Mo
    TRD OffRoad
    BANKS MONSTER EXHAUST ToyTec Lift TRD SuperCharger (March 2012)
    Go get the rims...you'll be happier you did. Then you go 265/70 17 on the tires. Zero power loss.
  5. Jan 21, 2013 at 4:13 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    265/70/17 is virtually the same size as 265/75/16. The reason why are finding info on different backspacing is for wider tires. 4.5 backspacing is good for 285/75/16 because the tire is to wide and will rub the upper control arms with the stock wheels, so you need a wheel that pushes the tire out farther from the UCA. You do not need new wheels, you can use spacers for the same result. Also look into 255/85/16, you will not need new wheels for this size and it looks great on a 3" lift. There may be some minimal rubbing with this size. If you go with 17" wheels you have a few more options like 275/70/17 or 255/75/17
  6. Jan 22, 2013 at 11:14 AM
    HogBalls
    HogBalls [OP] Hog
    Shane
    Thanks, I will look into the spacers and see what I can find.
