Help! New wheels now rubbing uca?
Discussion in '1st Gen. Tacomas (1995-2004)' started by lonzorizo, Sep 20, 2011.
  1. Sep 20, 2011 at 11:01 PM
    lonzorizo
    lonzorizo [OP] Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Just got new wheels put on yesterday. After driving on a curvy highway today I noticed a shuddering while on significant corners. Also, when braking heavily the truck did the same thing. Stopped numerous time to check lug nuts and what not and couldn't figure out wth was going on. When I finally got home 100 miles later I took a look at the UCA's. There seemed to be a spot where the tires rubbed the dirt off! This would explain the shuddering correct? Spring compresses on corners and while braking and UCA hits tire. I'm running 285/70/17 duratacs and the new wheels are 9" wide with a 4.5" BS. I was previously running the tires on tundra wheels which has a 5" BS and are 7.5" wide, ran this setup with a 1.25" spacer and had no problems. I'm running OME 881's in front with a 10mm top plate spacer. Never measured lift but I'd guess 2.25" ish? So would more lift stop the uca rubbing? Or aftermarket uca's? Or is the uca probobly not even causing the shuddering?lol. Hope somebody can shed some light for me! Here's a pic of the UCA and where it looks to be rubbed off.
  2. Sep 20, 2011 at 11:02 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Looks like you need wheel spacers
    check out Spidertrax
  3. Sep 20, 2011 at 11:04 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Either get wheels with a different BS or get spacers. I'm running 15x8 wheels with 4" BS, the tires are 12.50 wide and would not rub the UCAs.
  4. Sep 20, 2011 at 11:11 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Aftermarket UCA's usually correct alignment/suspension geometry.
    Sometimes they will correct rubbing. Usually not.
    Cheapest way to fix is spacers(even at $100-200 a pair)
    Expensive way is to buy new wheels with different backspacing(5"
    or trade your wheels.
    More lift will fix it..but if you lift it more, you'll need aftermarket UCA's anyway...
    So it's a toss up.
  5. Sep 20, 2011 at 11:18 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    I already have spidertrax but the reason I got new wheels was so I didn't have to use them anymore. I really don't want to use them now my front tires will be way too wide. And undefined 5" bs would bring the wheel closer to the uca's not farther. And I wont need new uca's if I lift it more. Plenty of people run a full 3" without aftermarket uca's. I just need to know if more lift will indeed fix the slight rub. If so ill just swap the 881's to 882's.
  6. Sep 20, 2011 at 11:21 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Ok I thought I was in the 2nd gen forum..lol. UCA's fix all your problems on 2nd gens.
    Your right 1st gen you can get away with 3" lift no problem on stock ucas.
    and again you got me on the wheels.
    I think I need sleep..that 95db siren I just put in got to me.
    Thanks for correcting me! :)
  7. Sep 20, 2011 at 11:21 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea but your new wheels only have 4.5'' bs. Before you had 5 right? minus the 1.25'' of the spacers so really your had 3.75 which is great for that size of tire. Just put the spacers back on
    You don't need more lift or new UCAs.
  8. Sep 20, 2011 at 11:32 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    I thought 4.5" bs was prime for our trucks on 285's. Like I said, the reason I just got wheels was to not have to run Spacers. I really don't want 3.25 BS up front. All I know is this sucks...really hope swapping to 882's will do the trick because I don't know what else to do. Don't think discount tire would let me exchange my rims or anything either.
  9. Sep 20, 2011 at 11:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It won't man lol just save yourself the money and put the spacers back on. Looks more bad ass anyways.
    Think about it. Just cuz the UCAs are outa the way for normal driving doesn't mean they will for hard cornering or offroading...
    I have stock rims with 1.5'' spacers on them and i am goin to run 33x12.5s next..
  10. Sep 21, 2011 at 12:08 AM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Just flexed out the front end. Stuffed each side and neither uca hit the tire. So for anybody reading this 4.5" is perfect for 285's. But now I have no idea wth the shuddering is coming from lol. The rub marks on the uca's must have been from the install.
  11. Sep 21, 2011 at 12:24 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    ideally on a gen1, to run 285s you'll want ~3.5"BS for good clearance. look for other rubbing spots.
    btw, do you want to sell your spidertrax spacers;).
  12. Sep 21, 2011 at 12:28 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bam...see. what about turning it all the way and flexing?? you did say you were turning..
  13. Sep 21, 2011 at 12:39 AM
    lonzorizo
    Lonnie
    Hoopa, Ca
    3.5" bs is definitely not needed for 285's. Iirc JLee runs 3.75" with 33x12.50's...and actually recommends 4" BS with 12.50's. 3.5" bs on a 285 would also cause more rubbing on the fenderwells. Like I said 4.5" BS works good only rubbing I have is drivers side frame full lock...no biggie. Stuffed and wheel turned both directions resulted in no rubbing.
  14. Sep 21, 2011 at 12:44 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    when the tire rubs on the uca, it's usually right where that shiny part is showing :D. slap the spacers on it tomorrow and drive it around the block and see if the shuddering stops.
  15. Sep 21, 2011 at 12:49 AM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Its not shiny at all. That's from my flash...trust me man its not rubbing the uca. Edited my post b4 yours too with more info about backspacing. Thanks for trying to help regardless though.
  16. Sep 21, 2011 at 12:58 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    hmmm... well i'm curious to find out too. by your description it does sound like it's definitely rubbing on something. hard braking and cornering compresses the suspension around so something is not happy.
  17. Sep 21, 2011 at 3:19 AM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    looks like mine. i was running 285/75/16 with 3 inches lift. thats from full lock left/right. put the spacer back on.
  18. Sep 21, 2011 at 7:24 AM
    lonzorizo
    Lonnie
    Hoopa, Ca
    What bs was you running? And I just said it doesn't touch the uca have you read what i been posting? Even if it did full lock that wouldn't result in the shuddering I feel. I wasn't Corning at full lock while doing 55mph. Or braking for that matter either.
  19. Sep 21, 2011 at 7:42 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    have you gotten an alignment yet?
    I still think you should run the spacers again..
  20. Sep 23, 2011 at 7:52 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Pulled into my house today and back left tire had a grinding noise. Took the center cap off and a lug nut came rolling out with the stud! Also the inside of the cap was filled with metal shavings. The whole tire moves back and forth after pushing on it. All the lugs are cross-threaded and aren't seated all the way! WTF Discount Tire!
