help : no a/c and fan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lilgerber, Jun 29, 2010.
  1. Jun 29, 2010 at 3:34 PM
    lilgerber
    lilgerber [OP] Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    okay its extremely hot here in the valley and for some reason my fan and a/c stopped working. i checked then a/c fuse and it was good and the connections in the back of the controls.
    On the controls the other orange button works( air circulation) so i know i have power to the controls. any Ideas please help thanks.
  2. Jun 29, 2010 at 3:49 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    check all fuses, something else may be effecting it.
    Have you done anything to the truck lately?
  3. Jun 29, 2010 at 3:52 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Could be the resistor. Check the heater fuse too, it powers the blower motor.
  4. Jun 29, 2010 at 3:57 PM
    lilgerber
    Aaron
    Fresno, CA
    no i pulled out my head uni to send in to get fix its been working fine for 2 weeks, and yesterday stopped. and my unit came in so want to do it all at one.
    Ill go check the heater fuse.
    remember no fan either .
  5. Jun 29, 2010 at 3:58 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x2
    There have been a few folks who have had that resistor pack blow. If only part of it goes, then the fan won't work at all of the speeds but usually one or two of them.
  6. Jun 29, 2010 at 4:00 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    +1
  7. Jun 29, 2010 at 4:08 PM
    lilgerber
    Aaron
    Fresno, CA
    fix it it was the 50 amp fuse it look fine still does but replaced it and it works now.
    thank you guys. :)
  8. Jun 29, 2010 at 4:14 PM
    NAAC3TACO
    Sparks, NV
    2014 SR5 DCLB 4x4
    Good to hear!:)
  9. Jul 23, 2010 at 1:26 PM
    peel.m
    peel.m Member
    flowmaster exhaust, K&N cold air intake
    Does anyone have a picture of the correct fuse? I opened up the fuse panel and it was overwhelming. Thank you advance and I apologize for my ignorance.
  10. Jul 23, 2010 at 3:30 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    A fuse "looking" fine is not the best method for troubleshooting an electrical issue. I would suggest investing in a multimeter.
  11. Jul 23, 2010 at 6:52 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Left side in this pic is the 50A Heater fuse. This same diagram is on the underside of the fuse cover in the engine compartment.
