Help: No air blown out center vents or windshield defrost area
Discussion in '1st Gen. Tacomas (1995-2004)' started by o4Taco, Jan 19, 2013.
  1. Jan 19, 2013 at 1:55 PM
    o4Taco
    o4Taco [OP] Member
    SoCalif
    Tacoma
    Need help fixing my ac/heater that does not blow out any air through the center vents or out the windshield area. The side vents and the feet blow strong. The light behind the blower speed knob also does not illuminate. I just bought a new climate control box and installed it, but it did not fix the problem. That is, the light behind the blower knob still does not illuminate and, the center and windshield vents do not blow air when the blend selector knob on the right end is adjusted (see photo).
    • Is there a servo that controls the direction of air flow that may be defective?
    • Is the direction of air flow controlled by a vacuum line from under the hood?
  2. Jan 22, 2013 at 5:11 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
  3. Jan 23, 2013 at 7:23 PM
    o4Taco
    o4Taco [OP] Member
    SoCalif
    Tacoma
    I read the instructions and it sounds helpful.
    Thanks.
  4. Sep 20, 2013 at 12:08 PM
    Unbrakeable
    Unbrakeable Member
    Bump, I have this same issue exactly. I have read the posts where people replace the air mix control servovalve/ actuator thing, went down to the wrecker and bought 2. I have learned that this is not the problem. It works fine, whatever controls the airflow is giving me my problem.
    I read a post about foam being stuck in the defrost vents but that isn't the case either. It only blows out of side vents and floor.
    Where is the unit that controls direction of airflow? A flap or valve or? If i know where it was i'd take it out and lube it up.
  5. Dec 11, 2015 at 3:17 PM
    ryanassist
    ryanassist New Member
    Same problem here. My airflow on HVAC is stuck in defrost. Will not blow anywhere else. Everything else works fine heat/cool mix selector, ac on off, etc..
  6. Apr 14, 2017 at 6:32 PM
    Bobo Lin
    Bobo Lin New Member
    2011 Red Tacoma TRD
    Hey Ryan. Did you ever get clarity on this? Same issue here.
    GQ7227 likes this.
  7. Aug 8, 2019 at 7:25 PM
    jtakeda
    jtakeda Well-Known Member
    2002 Turd
    Also having this issue if anyone has other ideas
  8. Aug 8, 2019 at 7:34 PM
    Xperivent
    Xperivent Well-Known Member
    ‘24 Supersonic ORP & '04 Impulse Red DC OR
    Also having similar issue
  9. Aug 9, 2019 at 5:05 AM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    When I got my truck a year and a half ago, the air knobs were no-ops, AC
    came out of (the middle?) vent, and turning the knob didn't change where
    the air came out at all, no air on the windshield... it was the beginning of
    summer, I don't remember now if I could make ac change to heat or not.
    Anywho... I ended up needing a new "Heater Box" (87150-04060) which required
    removing the dashboard... hope that'$ not your problem... when winter got here,
    though, I was glad I could turn on the defrost!
    -Mike
  10. Aug 9, 2019 at 5:28 AM
    Shiki Shabazz
    Shiki Shabazz Well-Known Member
    Tulsa, OK
    2003 Tacoma Dbl Cab TRD
    Although not a Tacoma, my wife's Jeep JK had the same issue last year and my research found that it was the heater core, and my mechanic (who is the best in my opinion of course :) ) said, would you mind if I tried flushing the heater core to see if that fixes the problem instead of replacing? I said sure. He flushed it and found all kinds of crap in it and he said if she took the jeep to her dealer (she bought it new in 2013) then a lot of the time they drop one of the stop leak tabs in the radiator as a "precaution." Anyway, fixed the problem, all vents worked, heat and air worked great. Just a thought.
