HELP! No reverse lights, blinkers, ac, shifter locked...
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Taco Nation, Mar 23, 2018.
  1. Mar 23, 2018 at 10:20 PM
    Taco Nation
    Taco Nation [OP] Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    As the title says I currently have no ac, the reverse lights don't come on when I shift into reverse, blinkers are not works, and when I shift into park the shifter locks and I have to use the button to release it. The dash lights indicating what gear the shifter is in (auto) do not indicate any gear. The blower fan is working but there is no cold air. Blinkers do not work period. When I hit the stalk nothing happens at all. I have to believe these are all connected but I can't find the issue. I checked all fuses I could think to check. Someone please know what is wrong with my truck.
    TXpro4X4 likes this.
  2. Mar 23, 2018 at 10:27 PM
    dome
    dome Well-Known Member
    Joel
    California
    2015 TRD OR DCSB 4x4
    Do you have brake lights when you step on the pedal?
    Shift lock circuit is IG1 (10A) fuse, and ACC (7.5A) fuse.
    Reverse lights are also related to that IG1 fuse, and without looking, I bet the other stuff is too. Try replacing it, even if it passes visual inspection.
    Edit: looks like this IG1 fuse is in the underdash panel on driver's side btw.
  3. Mar 23, 2018 at 10:28 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Almost sound as if the whole chase c
    Ground has taken a shit....why I'm not sure.
    HELP people!
    Raining? Water crossing?
    Or like you came out from work and this happened?
    tcjacado likes this.
  4. Mar 23, 2018 at 11:36 PM
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    Any offroading in water?
  5. Mar 24, 2018 at 12:01 AM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    did all these
    Rob Daman likes this.
  6. Mar 24, 2018 at 2:45 AM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    This is likely the case. I recently shorted out the reverse lights in my second gen and had similar symptoms, also the temperature was not displaying on the overhead but the compass did work. No cruise control. The obd2 code was no shift position. I think it was a 10amp fuse by the left knee, one if the ignition circuits. Replaced fuse, all is well.
  7. Mar 24, 2018 at 7:13 AM
    tw0leftskis
    0xApes
    Meta Verse
    electrical
  8. Mar 24, 2018 at 11:10 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    I do have brake lights when I step on the pedal but I will check those fuses in a minute. Thanks.
  9. Mar 24, 2018 at 11:11 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    No off-roading, no rain, and no new windshield. Thanks for the ideas though.
  10. Mar 24, 2018 at 8:40 PM
    tw0leftskis
    0xApes
    Meta Verse
    does your headlights
  11. Mar 24, 2018 at 11:46 PM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Headlights and fog lights still work. I haven’t checked every single fuse yet only the ones that stand out. Wasn’t going to check the head light fuse when the headlights work. That being said there are some I still need to check just haven’t gotten around to it yet. Only aftermarket accessories are tied into the blinkers and reverse light. I know that immediately raise a flag but those two accessories are not tied together so why would they both go out at the same time and not be related.
  12. Mar 25, 2018 at 12:03 AM
    tw0leftskis
    0xApes
    Meta Verse
    what kind of
  13. Mar 25, 2018 at 6:42 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Turn signals have switchback halos ties into them and reverse lights have some 18w led lights tied into them
  14. Mar 25, 2018 at 6:53 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Update: It was IG1. Might be a short somewhere
    Fifthwind and dome like this.
  15. Mar 26, 2018 at 10:53 AM
    tw0leftskis
    0xApes
    Meta Verse
    remove your
