Help! Noise diagnosis
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sgtacoma1, Jan 1, 2021.
  1. Jan 1, 2021 at 11:42 AM
    Sgtacoma1
    Sgtacoma1 [OP] Member
    2015 Tacoma v6 (trd off road)
    Hi everyone :) I have a 2nd Gen Tacoma, 2015 TRD Off-Road with about 77k.
    Got the oil changed recently and the next morning noticed a pronounced rumbling/vibrating sound that seemed to be coming from the engine compartment. Particularly noticeable when in drive with foot on the brake or when moving forward slowly.
    Goes away for the most part once the engine is fully warmed up and you're driving around normally. Haven't noticed anything else wrong with the truck.
    Here is a link to a video I took recording the sound...
    it becomes particularly noticeable around 1:45 and again around 2:35 (if you don't want to sit through the whole thing haha)
    https://photos.app.goo.gl/yYTu9z6nC5cUxeAQA
    Anyone else experience this, or any ideas what it might be?
    I saw some threads describing vibrating from the air intake where it goes into the fender, but I didn't think that issue extended all the way to 2015's...
    Thanks in advance!
  2. Jan 1, 2021 at 11:48 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check your heat shields on the exhaust system maybe one is loose.
    Where did you find that startup image for your radio?, that's sweet.
  3. Jan 1, 2021 at 11:57 AM
    Sgtacoma1
    Thanks! It definitely sounds like it's coming from the engine bay but I could be wrong. I will check that.
    I actually don't remember where I got the image for the radio o_O but I think I still have it on the thumb drive, I can send it if you want it
  4. Jan 1, 2021 at 12:03 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Thank's for the image, if you could get someone to record under the hood when the noise is occuring it would help narrow it down better.
  5. Jan 1, 2021 at 12:05 PM
    Sgtacoma1
    Agreed, and I wanted to do that, but unfortunately every time I stopped and put it in park the noise stopped :mad: maybe that will be a clue for someone here that is smarter than me.
  6. Jan 1, 2021 at 1:27 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    My air intake rattles occasionally. I loosen the clamp on the filter box then twist the hose clockwise till it's tight then retighten the clamp.
    This will effectively push the air intake down onto the metal where it passes through to be under the fender.
  7. Jan 1, 2021 at 1:43 PM
    Sgtacoma1
    Hmmm OK does it make a sound like in the video? I will look at that Thanks
  8. Jan 1, 2021 at 2:13 PM
    Larzzzz
    Larry
    MA
    I listened to it but wasn't able to pick it out. In drive, at a red light, I sometimes hear a rattling sound under the hood that goes away in neutral or when I step on the gas. When crawling asking it'll sometimes rattle as well.
  9. Jan 1, 2021 at 2:13 PM
    Sgtacoma1
    OK. thanks again :)
    Larzzzz[QUOTED] likes this.
  10. Jan 1, 2021 at 4:15 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Might they have removed your skid plate to drain the oil then didn't tighten the bolts when reinstalling?? OR, maybe stripped one of the bolts and your skid is vibrating??
    Superdave1.0 likes this.
  11. Jan 1, 2021 at 4:17 PM
    Sgtacoma1
    Thanks... Ill check that but I don't think so. The skid plate has a cutout to let you drain the oil without removing it. And if it was the skid plate I don't think the rattle/vibration would stop once the vehicle was hot. I'll crawl under in the morning though and double check haha
  12. Jan 1, 2021 at 5:10 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    I think it may be where your intake passes through the fender. Vibrating at the right frequency is causing a rattle. Try packing a rag or some foam around it and see if it stops. I have the same thing but I haven't figured out a permanent solution.
  13. Jan 1, 2021 at 5:15 PM
    Sgtacoma1
    OK! Interesting. I'll definitely double check that then, it's useful to know that you also have a 2015 and have that problem. I did a little reading on it and I THOUGHT Toyota rectified it with a TSB all the way back in 07-09 range.... :confused:
  14. Jan 1, 2021 at 5:37 PM
    winkel
    Corydon, IN
    I realize that but maybe they didn't.
  15. Jan 1, 2021 at 5:43 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    I can’t load your video but is this sound similar to yours? Listen closely. This is my truck and it’s gotten way louder ever since I uploaded this
    https://youtu.be/-nASlGFBpmg
  16. Jan 1, 2021 at 5:48 PM
    Sgtacoma1
    Somewhat similar, yours seems more pronounced and "steady" though...
  17. Jan 1, 2021 at 5:53 PM
    ALI3N_123
    Eric
    Austin, Texas
    Just like yours, it goes away if I shift from D to N and back to D, or I let go of the brakes and keep driving
  18. Jan 1, 2021 at 5:54 PM
    Sgtacoma1
    And I'm guessing you're not sure about the source of the sound either?
  19. Jan 1, 2021 at 6:19 PM
    ALI3N_123
    Eric
    Austin, Texas
    Correct
