Help! Noise from behind glove box in 15 Tacoma.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SoonerCody1985, Sep 12, 2019.
  1. Sep 12, 2019 at 1:21 PM
    SoonerCody1985
    SoonerCody1985 [OP] Active Member
    Cody
    Oklahoma
    2015 TRD Sport
    I have read every thread that I thought might be similar to what I'm experiencing but no luck so far. It is a noise coming from behind the passenger glove box. It almost sounds like its exhaust related. I only say that because it goes away when accelerating. I don't know if it could be a blower motor issue or not. Changing settings of the AC and turning it completely off does not resolve the noise. It is much more noticeable at low rpms when backing out of my driveway etc.
    Any help would be greatly appreciated!!!
  2. Sep 12, 2019 at 4:59 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Easy to do: pull the glove box door off (lifts out after opening and pulling little cylinder off) and pull the cabin air filter out see if any critters in the fan area or junk dropped in the fan. If not and no noise then look in the engine compartment for an exhaust leak at the flange gasket after the second cat.
