Help! Noise from my engine!
Discussion in '4Runners' started by tymebandit951, Aug 20, 2016.
  1. Aug 20, 2016 at 6:03 PM
    tymebandit951
    tymebandit951 [OP] Well-Known Member
    Boise, ID
    2013 4x4 DCSB
    So this is actually on my 1998 4Runner. I had the heads replaced last year but there is still a noise at certain RPMs. From what I can figure out its called "valve chatter". Any help in this matter on how to fix it? It only happens when I'm accelerating at about 2500 RPMs usually up a steeper grade.
  2. Oct 20, 2016 at 8:43 AM
    jaunty
    jaunty Well-Known Member
    99 V6 TRD Automatic 4x4
    Put some high octane in there and see if it goes away.
    Check your MAF sensor. It's easy to clean and will cause pinging. Does it sound like a coffee grinder coming from the engine?
    EDIT***Sorry just realized this was months old :)
  3. Oct 21, 2016 at 2:34 PM
    tymebandit951
    Boise, ID
    2013 4x4 DCSB
    It's fine! It still makes the noise. I already run 93 octane through it. I'll check the MAF sensor. Umm not so much coffee...eh maybe a little. More like boiling water popping in a pipe.
  4. Oct 21, 2016 at 2:37 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    are the rocker arms adjustable?
  5. Oct 21, 2016 at 3:16 PM
    tymebandit951
    Boise, ID
    2013 4x4 DCSB
    Uhh I couldn't tell you honestly. How could one tell if they were?
  6. Jan 13, 2017 at 10:33 PM
    Booster
    Booster Well-Known Member
    1999 TRD 4Runner
    Bilstien Shocks 2.5 Inch Lift TRD supercharger TRD Exhaust Transmission Cooler K&N Intake Aftermarket headers Performance Parts Progressive Springs
    To be honest it kind of sounds like your car is pinging. A high pitch noise kind of a jittery noise. I just had my heads done. Were they both the same age? That could of happened because the heads weren't the same age. That would lead to a kind of 'harmonic' vibration leading to other noises. If it isn't that i'd check the fuel filter/get high octane fuel from a different spot.
    Your car may be running too lean. You can ask your mechanic to drive your car, and graph the MAF data. Usually they can adjust the settings depending on how much gas the car is injecting. Mine was running too lean. 100 dollars later it's all fixed, and no more pinging
  7. Jan 15, 2017 at 4:59 AM
    tymebandit951
    Boise, ID
    2013 4x4 DCSB
    I was kinda thinking about that it might be running lean too. Thanks for the input, I'll give that a try!
