Help! Not sure if Supercharger is running right!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by themanknownasstin, Jan 11, 2014.
  1. Jan 15, 2014 at 4:59 PM
    #61
    themanknownasstin
    themanknownasstin [OP] Active Member
    Utah
    13 TRD Sport Supercharged
    TRD supercharger. Airaid CAI.
    What did he end up doing to get his going? My fear is what this might be doing to the motor while it isn't working right.
  2. Jan 15, 2014 at 5:36 PM
    #62
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    You sure the SC belt is on?
  3. Jan 15, 2014 at 5:52 PM
    #63
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    ^This, and please let us know the outcome OP.
  4. Jan 15, 2014 at 6:20 PM
    #64
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    After reading through this again i think there are a few questions to answer that may help. 1: how many miles on the truck? my s/c has gotten better with more miles. 2: have you checked the little nipple on the back of the s/c to make sure the plug is still there? mine had a little hole in it and threw a cel, and made the truck run like crap. 3: what are you running for fuel? 87 will make it run like crap, so that's something to think about. supercharger whine in my truck doesn't depend on rpm as much as throttle position. i can get it to make noise at 2k if i punch it or be quiet until 35 if i accelerate easily.
  5. Jan 15, 2014 at 6:42 PM
    #65
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    *pasted from a pm I sent the OP, figured it might be useful for everyone*
    I recommend that you double check the vacuum connections going into the S/C. There are two hoses that go into the unit horizontally and one that attaches on the bottom vertically. All of these hoses are on the driver's side. Make certain that they are attached to the S/C correctly, and if you are able to open that link I posted in the thread earlier you can see if they are routed to the right places. The one on the bottom likes to shimmy loose where it connects to the engine so follow that one with your hand back there to make sure that it is connected snugly.
    Also, check to make sure that your bypass valve is not getting stuck open. Here's a quick vid to show proper function when depressing and releasing. It should snap back with no hesitation or disruption. This can be reached from the passenger's side. I have my cover off in the video, but that is not necessary to do.
    https://www.youtube.com/watch?v=l62wlq9mXvY
    I'll check back into the thread tomorrow to see what you have run across.
    Biscuits likes this.
  6. Jan 15, 2014 at 6:43 PM
    #66
    themanknownasstin
    Utah
    Has 3900 miles. Was installed with 1800. I have not checked any nipple on the back of it. I am running 91 octane. and the belt is on, the SC does work. But I don't think it's very much more power than stock the way it's running right now on my truck. To feel any upgrade in power I have to be 3/4 of the way down on the gas.
  7. Jan 15, 2014 at 6:50 PM
    #67
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Try 93 octane. Doesn't Sunoco have 94? You need all you can get.
  8. Jan 15, 2014 at 6:55 PM
    #68
    memario1214
    Colton
    Missoula, MT
    That won't change anything. If he's not making boost he might as well be running lower octane fuel. I don't think the fuel in his tank is the issue here.
  9. Jan 15, 2014 at 8:27 PM
    #69
    themanknownasstin
    Utah
    Well I have an appt tomorrow at 4:30 with the dealer again. This time I will make sure they drive it. They are going to be blown away by how weak it feels. And they are going to look like fools for giving me the run around last time. Even though I was the MORON who didn't argue back. I just assumed it was because I had never been in a SC Tacoma before. I'll let you all know how it goes. Thanks again.
  10. Jan 16, 2014 at 7:48 AM
    #70
    themanknownasstin
    Utah
    So I have my appt today with the dealer. Anything important I can have them check besides the test drive? Should I have them test the boost? See if there is a new "mapping" for the 13 SC?
  11. Jan 16, 2014 at 7:58 AM
    #71
    brex
    brex Well-Known Member
    Since I didn't update yesterday...my truck doesn't whine at idle in park, and only very slightly in gear at idle. Under normal acceleration it will get noticeable just before 2000 RPM, and under more load (like going up a hill) will be much louder and noticeable down around 1000 RPM.
    No hesitations or stumbles.
  12. Jan 16, 2014 at 8:13 AM
    #72
    themanknownasstin
    Utah
    Thanks for the info. I don't hear mine til around 3000 - 3500 RPMs. I would still like to test drive yours if possible. What time do you get off?
  13. Jan 16, 2014 at 8:46 AM
    #73
    brex
    Regular business hours for the most part.
  14. Jan 16, 2014 at 9:26 AM
    #74
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    check the vaccum bypass actuator and associated hoses.I've had one dealer screw up the plumbing. Sounds like the bypass actuator might be stuck open keeping it from making boost
  15. Jan 16, 2014 at 9:28 AM
    #75
    themanknownasstin
    Utah
    Is that the same as the valve? I checked that last night and it seemed to move up and down just fine.
  16. Jan 16, 2014 at 9:29 AM
    #76
    CtTaco
    Eric
    Connecticut
    I believe its on the drivers side on the back of the sc. it should move when you hit the gas hard to close in order to make boost. did you recently change plugs?
  17. Jan 16, 2014 at 9:59 AM
    #77
    themanknownasstin
    Utah
    Yea that is the same valve. I didn't open up the charger to see, but it was down when I tried it. So is down closed and up is open? I didn't change plugs at all. This SC was installed in July. Got all the paperwork showing the install. And how they installed it with the Airaid CAI already there. So if they blame it was because of the CAI, I will then counter that they shouldn't have installed it then.
  18. Jan 16, 2014 at 10:03 AM
    #78
    CtTaco
    Eric
    Connecticut
    im gonna suspect some bad hose routing on the dealer's part. when I had my SC done on my 2008 the dealer never even hooked up the fuel pressure regulator!! If they've never done one before its quite conceivable that they could have made a hose connection error. Did they give you the SC install instructions back with the original parts? maybe take a look at the book yourself and poke around under the hood to see if you can see anything?? If you dont have the instructions, let me know and I'll see if I can dig mine up and scan those pages for ya...
  19. Jan 16, 2014 at 10:27 AM
    #79
    themanknownasstin
    Utah
    That would be awesome! They didn't include anything except the receipt. I bought it from someone selling it this month. And that's when I noticed the issue. I asked the seller and he said there was never anything wrong with it to his knowledge. He and I went back and forth for a while about it. And his first experience with a SC was the same as mine. So both of us have no idea if soemthing is amiss or not. I still believe there is because of the way it acts off the line. If I punch it hard it doesn't take off like I have read most on here. It has to get up to 3000 RPMs and then the whine and the SC kicks in. But again, that's only if I have the gas all the way down. It's as if it has a timer of some sorts for when the thing will start using the SC. I get normal engine sounds and power off the line. And only get SC noise and power if the gas is too the floor.
  20. Jan 16, 2014 at 10:37 AM
    #80
    CtTaco
    Eric
    Connecticut
    Ok I scanned the two pages of vacuum line diagrams into a PDF. PM me your email and I will send the file over to you.
